Tire size for 05 GT
Old Jun 2, 2006 | 11:47 PM
steve vercolio's Avatar
steve vercolio
Default Tire size for 05 GT
Can anyone tell me if 265x50 tires with 18x9 wheels will work on an 05 GT? Thanks for your help!
Old Jun 3, 2006 | 12:24 AM
Stoenr's Avatar
Stoenr
Default RE: Tire size for 05 GT
sure it will work, a little larger in diameter than stock. Check fron turning clearance tho, but should be ok.
Old Jun 4, 2006 | 05:39 PM
dtuna42's Avatar
dtuna42
255/45/18 on 18x9 fit like a glove on mine. Same outside diameter as the stock 235/55/17, so I didn't have to reflash the computer to correct the speedometer. Your size is close, but it is different, so you may have a slight difference in outside diameter, which means you may have to reflash (if you don't have a tuner, you'll need one), or your speedometer may be wrong.
I wanted to add that my rims have a 25mm offset. I'm not sure what you have, but the issue with turning radius is related to the offset more than the size.
Old Jun 4, 2006 | 07:00 PM
Refire05GT's Avatar
Refire05GT
Well since this looks like a good time to ask, What is the minimum/maximum/optimum offset that we should be using to make sure our tires dont rub? I will eventually be going up to 19 inch rims, and am looking at 265/40/19 for tire size. It is the closest I can get to stock size, so how much offset should I get?
Old Jun 4, 2006 | 08:10 PM
drbobvs's Avatar
drbobvs
It's a 6" backspace 24mm offset
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
M3hunter
Sep 5, 2015 03:42 PM
Sep 1, 2015 08:16 PM
