Installed Hurst Shifter and CDC Sequentials
Old Jun 8, 2006 | 08:35 AM
zx9rpilot's Avatar
zx9rpilot
Default Installed Hurst Shifter and CDC Sequentials
Got a few things out of the way in the past few days:
CDC Dynamite Stick Sequentials: Install was GRAVY! Took about 20 minutes for both sides. Directions and quality were very good. Probably should've done it earlier; looks preety cool. Have already have a few people pull up next to me and ask if the care came like that.
Hurst Competition Plus Short Shifter: Again, really easy to install. Instructions provided were good but used this website the most
http://www.fordmuscle.com/archives/2...fter/index.php
Initial feel is best described as "notchy." It is much shorter as the link above suggests. It takes more effort and gives you a decisive "click" when it goes into gear. 2nd to 3rd is GREATLY improved. Honestly, I'm surprised that I still have 3rd gear I've ground it so many times with the stock shifter. If the shifter takes some break in as everyone says, it will be perfect.
My $.02
Old Jun 8, 2006 | 09:35 AM
McChicken's Avatar
McChicken
Default RE: Installed Hurst Shifter and CDC Sequentials
Those sequentials look really cool. I think they're going to be my next mod. Is the CDC kit a direct plug in or do you have to splice it?
Old Jun 8, 2006 | 10:49 AM
zx9rpilot's Avatar
zx9rpilot
Everything is plug 'n' play. The majority is just a pigtail that plugs in to the existing harness. The only different thing is a black wire that you have to push through a rubber grommet into the tail lamp harness. Once there, you plug it into the only open terminal on the innermost light socket.
Sounds confusing, but it was VERY easy.
Old Jun 8, 2006 | 12:21 PM
jdback19's Avatar
jdback19
Can i get a link for those sequentials i really want some dont know were to find them though??
Old Jun 8, 2006 | 01:39 PM
McChicken's Avatar
McChicken
ORIGINAL: zx9rpilot
Oh yeah....pretty sure I know what you mean. I was looking over the webelectric online instructions and theirs involves something similar to that. Easy is good, too.
Old Jun 8, 2006 | 03:46 PM
Cowtown's Avatar
Cowtown
Installed my sequentials on Sunday when I did my Flowmasters, they are a really nice kit and I really am pleased with the results. I've received a lot of compliments on them.
Old Jun 8, 2006 | 07:38 PM
jdback19's Avatar
jdback19
Were do you get the sequentials at??
Old Jun 8, 2006 | 07:58 PM
Red_Stallion's Avatar
Red_Stallion
http://www.classicdesignconcepts.com...splay/635.html
Wish they weren't so expensive, I bet with a bit of electronics knowledge it wouldn't be too hard to build one.
Old Jun 8, 2006 | 08:49 PM
CDW63's Avatar
CDW63
Thanks guys, just ordered them. You need to be specific on 05 or 06 model, apparently Ford changed the wiring harness between years.
Old Jun 8, 2006 | 08:56 PM
austijc's Avatar
austijc
I got mine from here. Not sure if they're the same:
http://www.webelectricproducts.com/
The reason I went there is they were the only ones that said they worked in the 2006 at the time.
I just noticed on their site that they have a pony grill insert for the GT. Has anyone tried on of those?
