Keyless remote question
Old Jun 28, 2006 | 09:11 PM
Skoshi42's Avatar
Skoshi42
Default Keyless remote question
I have an 06 Mustang with keyless remote, yadda yadda... and when I unlock my doors, my turn signals dont flash? is this how it supposed to be? Just the other day, I was watching some tourists in their rental 06 Mustang, he used the keyless entry and when he unlocked his doors, the turn signals flashed twice.. and when he locked it, it flashed once... Mines only flashes once when it locks.. Is it just me, or does everybody elses Mustang do that?
Also please dont get mad for me asking, i didnt know where else to ask or post.
Old Jun 28, 2006 | 09:14 PM
BLACK06GT4ME's Avatar
BLACK06GT4ME
Default RE: Keyless remote question
Had to check but mine is the same as yours. If it's a problem you aint alone.
Old Jun 28, 2006 | 09:41 PM
ScottRNelson's Avatar
ScottRNelson
Mine flashes once when I lock it and doesn't flash anything when I unlock it. I'll get two flashes if I lock it when the trunk is open.
Old Jun 28, 2006 | 09:52 PM
BAMFstang's Avatar
BAMFstang
Same with mine.
I thought it was odd because every vehicle I've had with keyless entry always flashed the lights when locking and unlocking.
Old Jun 28, 2006 | 10:34 PM
classj's Avatar
classj
Same here. Maybe cars with the active anti theft are different.
Old Jun 28, 2006 | 10:52 PM
Anomalus1's Avatar
Anomalus1
ORIGINAL: classj
I have the active alarm system and mine only flashes when i lock the car, doesn't flash when i unlock it.
Old Jun 28, 2006 | 11:25 PM
lureynol's Avatar
lureynol
Mine don't flash when I unlock it, my theory goes that there are car thiefs who will hang in lots and wait until they see those flashes, while the owner is still a distance from their car, and so hop in and quickly steal the car, but that may be just my paranoid mind.
Old Jun 28, 2006 | 11:41 PM
BigDave's Avatar
BigDave
It would help if the thief had the keys...
Old Jun 28, 2006 | 11:48 PM
Skoshi42's Avatar
Skoshi42
Okay, i guess im not the only one.... maybe it was just an earlier 05 Mustang, and Ford just did away with it, just like their Remote Power Down windows.. (Remote Power Down- by holding unlock on the key fob, all doors unlock and windows automatically roll down)... thanks anyway guys, this is a great forum BTW... glad to see others enjoy their mustang just as much as I do mines...
Old Jun 29, 2006 | 12:21 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
THIS is what the book says... Page 67 and 68.
If there are problems with the remote entry system, make sure to take ALL remote entry transmitters with you to the authorized dealer in order to aid in troubleshooting the problem.
Unlocking the doors
1. Press and release to unlock the driver’s door. Note: The interior lamps will illuminate and the active anti-theft system (if equipped) will disarm.
2. Press and release again within three seconds to unlock the passenger door.
Locks and Security
Locking the doors
1. Press and release to lock all the doors. Note: The interior lamps will turn off (unless the dome lamp control is in the full-up position), and the turn signal lamps will flash if all doors, trunk and hood (if equipped with active anti-theft system) are closed and locked. If the vehicle is not equipped with the active anti-theft system, the turn signal lamps will flash if all doors and the trunk are closed and locked.
2. Press and release again within three seconds to confirm that all the doors are closed and locked. Note: The doors will lock again, the horn will chirp once and the turn signal lamps will flash once more. If any of the doors, trunk or hood (if equipped with active anti-theft system) are not properly closed the horn will make two quick chirps and the turn signal lamps will not flash. If the vehicle is not equipped with the active anti-theft system, the horn will make two quick chirps and the turn signal lamps will not flash if the doors and the trunk are not closed and locked.
Sounding a panic alarm
Press to activate the alarm. The horn will sound and the turn signal and interior lamps will flash for a maximum of approximately 3 minutes.
Press again or turn the ignition to the 2 (ACCESSORY) or 3 (ON) position to deactivate, or wait for the alarm to timeout in 3 minutes. Note: The panic alarm will only operate when the ignition is in the 1 (OFF/LOCK) position.
Opening the trunk
Press once to open the trunk.
• Ensure that the trunk is closed and latched before driving your vehicle. Failure to properly latch the trunk may cause objects to fall out or block the driver’s rear view. The remote entry system allows you to open the trunk while the ignition is in any position. However, if the ignition is in the 3 (ON) position and the vehicle is in motion, the trunk will not open if the vehicle is moving 3 mph (5 km/h) or faster.
I have an UNGO Addidional Security system along with Remote start on my car... it flashs once and chirps once when I lock the car.... Flashes twice and chirps twice when I unlock the car.
