Anyone had this problem
Old Jul 7, 2006 | 01:10 AM
Stroken97's Avatar
Stroken97
Default Anyone had this problem
I have experienced a miss or hiccup after cruising on the interstate for awhile. Usually on a long trip and after using most of a tank of gas. It only happens when I pull off the interstate and stop then as I hit the accelerator the engine hiccups before taking off. Only happens then and does not repeat itself until after another long interstate drive. I have used the my predator looking for a trouble code and nothing is ever found. I don't want to go to Ford and have to put my stock setup back on and reflash it.
Any ideas?
[IMG]local://upfiles/30874/48DB36934E4545E08AB870508D5F36A3.jpg[/IMG]
Old Jul 7, 2006 | 03:23 AM
MSgt46270's Avatar
MSgt46270
Default RE: Anyone had this problem
ORIGINAL: Stroken97
Any ideas?
I had the same problem and I found out that there's a TSB for it. Dealer replaced the fuel pump with a better one, so they said.
Here's a link for the TSB http://www.2005stang.com/gallery/alb...hesonaccel.pdf
Old Jul 7, 2006 | 09:12 AM
Daniel60's Avatar
Daniel60
Sweet Car Master Sergant.
[IMG]local://upfiles/11318/1C88149DF11242FB9563B469BE5820E0.jpg[/IMG]
Old Jul 7, 2006 | 08:47 PM
cwall583's Avatar
cwall583
Hmmmm
I have had the same problem. Drive on the freeway for 40 minutes then try to pull away from a light after exiting the freeway and you would swear I dumped the clutch without giving it gas, embarassing. People think you missed a shift or can't drive. Then after it does it that one time it doesn't do it again until I have driven it on the freeway again. I was wondring last week if the heat was a factor, but based on the TSB I guess not. Looks like another trip to the dealer.
Old Jul 7, 2006 | 09:05 PM
555*'s Avatar
555*
Cmon now. There is this thing called a search button. Ive seen this topic posted at least 3 times so far.
Old Jul 10, 2006 | 01:45 AM
Stroken97's Avatar
Stroken97
That's it exactly!. Now to see if I should remove the C & L and reflash it or just take it in. Thanks
Old Jul 10, 2006 | 01:46 AM
Stroken97's Avatar
Stroken97
What just three times!
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 25, 2015 06:48 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
