20x10 Tire questions
Old Jul 11, 2006 | 11:41 PM
ANBAUTO's Avatar
ANBAUTO
Default 20x10 Tire questions
Those of you running the 20x10 in the rear what size tire have you gone with? My first choice was 285-30-20 but those are out of stock so my other choices are 275-30-20 or 285-25-20 or can i fit a 305-25-20 mind you the fronts are going to be 255-35-20 and my car is lowered with a 2 inch drop. Thanks in advance!
Old Jul 11, 2006 | 11:45 PM
bl1nk's Avatar
bl1nk
Default RE: 20x10 Tire questions
Go 305! Those would look sick from the back! No idea if theyd fit but if they do, definately go for it.
Old Jul 12, 2006 | 12:43 AM
ANBAUTO's Avatar
ANBAUTO
i will if they fit, thats why im hoping someone might know
Old Jul 12, 2006 | 01:26 AM
Tmack's Avatar
Tmack
I am running 275/40, but I've seen as large as 315/35 with no rubbing.
Old Jul 12, 2006 | 01:31 AM
ANBAUTO's Avatar
ANBAUTO
But the thing is im going to have 20's and i have a 2 inch drop
Old Jul 12, 2006 | 01:55 AM
06GT4RAD's Avatar
06GT4RAD
I am running a 285/30 on a 20x10 Here is a picture. Also prior to lowering
Richard
Old Jul 12, 2006 | 02:34 AM
ANBAUTO's Avatar
ANBAUTO
do you think i can fit the 305's on there?
Old Jul 12, 2006 | 01:12 PM
06GT4RAD's Avatar
06GT4RAD
It will be close. Not sure there will be enough clearance but i do not know for sure.
Richard
Old Jul 12, 2006 | 02:39 PM
grafix66's Avatar
grafix66
I ran 255/35 front and 275/35 rear on a staggered setup. If I had it to do over again, I'd run wider in the rear...at least 285. As for clearance, I think the 305s would fit, but it depends on the backspacing of your wheels, also. But, a 305/25? That's not a lot of sidewall. Your ride will definitely suffer.
[IMG]local://upfiles/28485/138943CC1C8A40309C85B15A5DF60D53.jpg[/IMG]
Old Jul 12, 2006 | 02:41 PM
ANBAUTO's Avatar
ANBAUTO
yea i know im kinda limited to a certain tire (sponsors) because of whats available
