Whats the width of stock 18 inch polished
Old Aug 5, 2006 | 10:54 PM
bodyputtyless's Avatar
bodyputtyless
Default Whats the width of stock 18 inch polished
Guys and Gals, whats the width of the stock 18 inch polished aluminum wheels? Thanks.
Old Aug 6, 2006 | 12:00 AM
wbr351's Avatar
wbr351
Default RE: Whats the width of stock 18 inch polished
8.5"
Old Aug 7, 2006 | 11:38 PM
fairlane292's Avatar
fairlane292
50mm offset
Old Aug 8, 2006 | 01:42 AM
Nadelle's Avatar
Nadelle
next question....how wide of a tire can you fit on the 18x8.5 wheels?
stock is 235/??/18 seems kinda skinny on that wide of a rim
Old Aug 8, 2006 | 01:47 AM
classj's Avatar
classj
I am thinking of upgrading to a 255-45-18 myself
Actually, narrow tires on wide wheels makes for a sharper handling car. If you look at any E46 M3. The tires look small for the wheels. That is done purposly for handling.
Old Aug 8, 2006 | 01:52 AM
fairlane292
Best bet is to go to tire mfg sites as they show rim width range for each tire size. Once you have the specific tire mfg chart in front of you it's pretty easy to select the tire you want. You'll be able to see the diameter or Revs per mile which you can compare to OE to know the difference in height (diameter) you are talking about with any selection. I would but w/o studying/comparing mfg charts. They all have them and if not available online they will fax or send them to you. Generally all mfg are about the same on width and diameter per tire size; you'll see this when you get a couple charts in front of you. ...Jim
Old Aug 8, 2006 | 02:18 AM
doodad's Avatar
doodad
l got 18' factory pholished rims too and l wanna put 315s on.. if they are not gonna fit on those rims, then l am gonna get new rims.. any help?
Old Aug 8, 2006 | 02:56 AM
Diabolical!'s Avatar
Diabolical!
ORIGINAL: doodad
You'll need to go with a wider rim. You might be able to wedge tires that wide onto your rims, but their structural integrity would be severely compromised.
Old Aug 8, 2006 | 04:54 PM
scramblr's Avatar
scramblr
255s is the biggest you should go with a 18x8.5. As stated above, you can squeeze a larger tire on there, but not advisable. I'm running 18x8.5 255/45 upfront and 18x9.5 285/40 out back...
Old Aug 8, 2006 | 05:44 PM
bodyputtyless
I was trying to determine if I could use my stock tires on the 18 x 9 inch chrome bullits.
