tree sap?
Old Aug 19, 2006 | 02:25 AM
8cd03gro's Avatar
8cd03gro
Default tree sap?
I have something that looks like tree sap on my rear bumper...no idea how it got there, but i want it off and i can't get it off!!! how do you think i could get it off?
Old Aug 19, 2006 | 02:35 AM
petepete's Avatar
petepete
Default RE: tree sap?
2 things. there are adhesive removers for cars that usually work. Second thing i noticed this one is weird. I bought a mr clean auto wash for the times i dont have time to wash the car. You have to spray it on and let it sit for a minute. The sap for some reason slides off the car. Then you spray the toweless dry on it. Pretty amazing for doing no work. Plus if you have other cars you dont like to wash as much its useful. I use it on my hummer becaus eits too damn big to work on it i just wax it after. Ill prolly use it on my audi that just got here today too for the first couple months because itll have the new paint shine
Old Aug 19, 2006 | 02:36 AM
Country1969's Avatar
Country1969
I have a 2005 Mustang and I never had any sap on it yet but I found this:
How to Remove Tree Sap
To remove the tree sap from your vehicle's surface, you can use finger nail polish remover on a cotton ball. After the sap is removed, make a paste of water and baking soda to wash the affected area, then apply wax.
Another method to remove the sap is to use mineral sprits (it will also remove tar). Use a soft, terry towel, or wash cloth dampened with mineral sprits. After removal, wash the car and apply wax to the affected area.
Tree sap can also be removed by using a water-soluble paint brush cleaner. A common household solution is bacon grease or lard. Just rub it on, and off comes the sap. To get tree sap off of your hands, simply rub mayonnaise on them and wash it off. To remove tree sap and other substances, you can use common solvents like lighter fluid, rubbing alcohol, WD-40 or even Skin-So-Soft bath oil.
The way to use those materials is to let them do their work of dissolving (in the case of alcohol) or softening (in the case of oils), enough to rub off the remaining sap. If you use the oil, wash the car afterwards to remove it.
You can also use commercial wax and grease-removing products available at auto supply stores. Be sure to wash and dry the car before applying the wax and grease remover. Then dampen a clean cloth with the solvent and rub the affected area. It may require several attempts if the sap is very thick or extremely hard. The surface may appear hazy after the solvent evaporates, but a good wax application will eliminate the haze and complete the job.
Removing tree sap from a car's finish is a bit more difficult than tar, as hardened sap can scratch your paint. I've found that by hand-rubbing the sap spots with mineral spirits or denatured alcohol, I'm able to easily remove the sap without damaging the finish. Mineral spirits and denatured alcohol acts as a solvent to break up and dissolve the sap.
If there is a large amount of sap on the car, or if the sap has been left on the finish for an extended period of time, it can be a lot of work to remove. For these cases, you can try hitting the affected areas with a light-duty buffing compound to remove the hardened surface on the sap spots. Then you can use mineral spirits or a similar solvent to remove it. The light duty buffing compound softens the sap so the solvent can do its job. The goal is to use the least pressure possible to reduce the risk of scratching the paint. After removing heavy sap, always buff the treated areas with a good polish to clean up any marks created during hand-rubbing with solvent. The treated area must also be re-waxed.
Another technique is to use orange based solvents and children's molding clay. Apply a bit of the solvent and rub with the clay. It is abrasive enough to scrub off the sap which has been broken down by the solvent.
The chemicals used to remove road stains can also remove your wax or sealants. After removing tar, sap or bugs, plan to spot wax or re-wax your vehicle. If you don't have time to wax right away, use a quick detailing spray that contains wax. A quick spray wax is great for this kind of spot waxing, too.
Old tar, tree sap, and paint over-spray can be easily removed with a miraculous new product called automotive clay. As you rub it across any type of surface (paint, glass, plastic, metal, rubber, vinyl) it instantly sticks-to and pulls-off all contamination that is stuck to the surface. Here's how to use an automotive clay bar:
To use the automotive clay, spray a water-based lubricant on a small area of your car and rub the bar back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Clay bars are fairly sticky, and they cannot be used dry.
After a few passes with the clay bar, rub your hand over the area to feel if the surface contamination was removed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft terry cloth towel, and buff to a nice luster. Just like waxing, work in small areas.
Check the clay bar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint.
When you're finished claying your car, you should go over it with a pre-wax cleaner to finish cleaning the paint and restore essential oils. Then, protect your newly cleaned finish with one or more coats of rich Carnauba wax
I hope you will find something that you like here. Like I said, I never had any sap so I can't tell you what really works.
Just found another thing: Use a ice cube
That ice cube trick really works without damaging the paint. The sap gets cold, fractures, and falls off with very gentle pressure
Old Dec 11, 2006 | 12:24 AM
glastron's Avatar
glastron
I have two spots of tree sap on my car, have for the last couple weeks. I washed the car today, and then tried the ice cube deal. It didn't work for me. I then tried the WD-40 deal, it loosened up the sap, and I got some of it off. When I waxed the car, most of the rest came off, however there is still a little bit left on. I plan on claybaring the car in the near future, and that should get rid of the rest of it.
Old Dec 11, 2006 | 12:48 AM
drbobvs's Avatar
drbobvs
+1 on the WD40, it's worked for me too.
Old Dec 11, 2006 | 12:56 AM
fairlane292's Avatar
fairlane292
Peanut butter will melt most types of tree sap. ...pretty amazing.
Old Dec 11, 2006 | 12:58 AM
drbobvs's Avatar
drbobvs
Really??? Definitely gotta try that. Will have to pry the JIF outta my wife's hands though.
Old Dec 11, 2006 | 01:08 AM
fairlane292
Have used it for removal of sap from hands; once this lady at a party at our house got a lot of it in her hair cause she was leaning back against a big pine tree... ...maybe a few too many drinks. Anyway pulled a lot of peanut butter through her hair and "magic"; all melted away.
Just removed several areas of sap on my daughters 06 Eclipse. If you get it in a week or so should work pretty fast; the longer you wait, the harder this stuff gets and even the peanut butter while it still works will take longer to dissolve it. I see one guy said lard or bacon fat... must be somethin about the oil aspect of these substances. I like the smell and taste of peanut butter better than these others though. Should take care of it... good luck.
Old Dec 11, 2006 | 03:31 AM
ilduce321's Avatar
ilduce321
I've used Turtle Wax Bug & Tar Remover...works well
Old Dec 11, 2006 | 03:39 AM
Fast Toys's Avatar
Fast Toys
Banned
ORIGINAL: ilduce321
X 2 works great. I believe it's just kerosene though (smells like it) LOL
dubarado
Dec 23, 2015 01:16 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sep 16, 2015 03:07 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
Wesley1995
Aug 30, 2015 02:01 PM
