Little help :)
Old Sep 3, 2006 | 11:43 PM
Apoptosis's Avatar
Apoptosis
poptart tits
Default RE: Little help :)
ORIGINAL: s2k
"girl that i know"
ive just never seen this before how did someone you know get the keys?
It's obvious, she gave him a "hummer" [&:]
Old Sep 3, 2006 | 11:49 PM
bahbahblacksheep's Avatar
bahbahblacksheep
I don't know why you would let your mom drive your stang.
I don't even let my wife drive it...well, except one time when I had too much to drink and I made her so nervous that she said she would NEVER drive it again hahahaha.
Anyways, with regards to dash rattles...yes I have some. Go to the dealership and tell them to look at the A-pillar...sometimes loose wires rattle. Also read somewhere about a bolt that needs to be tightened behind the passenger side airbag that causes a metalic rattle.
Just turn up the radio and get a louder exhaust and all the rattles go away
Old Sep 3, 2006 | 11:54 PM
bl1nk's Avatar
bl1nk
I also have a rattle in the drivers side corner, near where the window meets the dash. It only happens when I go over a road section that looks eaten away by water or something.. not pot holes, not speed bumps, nothing but rigid roads...then it vibrates really fast for a couple seconds and stops.. No idea what it is.. Ive had people suggest that it might be wires underneath the dash but I looked and didnt see anything near where I think the sound is coming from... really hope someone finds out what it is because here the roads blow, so it happens alot.
Old Sep 4, 2006 | 02:54 AM
chipschwab's Avatar
chipschwab
yeah same type of rattle... is it hard to take apart the dash on our cars? i would secure everything really well while i was in there if i could get in. Also i dont know why i let the girl have the keys, just kinda felt like an *** if i did anything but, but i learned a lesson im not lettin anyone drive it. My mom filled it up with gas and that was the point of her driving it that day and she has a 350z so she kinda knows how to drive like i do.
Old Sep 4, 2006 | 04:47 AM
rex7010's Avatar
rex7010
RATTLE FIX.. this NEEDS TO BE STICKIED AS I am very tired of typing it..
Remove A-pillar.. the rattle is at the A-pillar where it meats the dash btw..
put some grease.. ( slide pin grease from Honda is what I used ) on the clips that hold the
A-pillar piece to the car.. problem gone.. at least it is on mine...
P.S. if you use cheap grease the problem WILL come back in time... ( Honda grease will stand on its end .. as a example of how good it is ) plus it was free as I use to be a Honda/Acura mechanic for over 20+ years...
Rex
Old Sep 4, 2006 | 04:59 AM
bl1nk's Avatar
bl1nk
Thanks, Ill try it out.
