2007 stereo replacement
Old Sep 4, 2006 | 10:51 AM
siggy14's Avatar
siggy14
Default 2007 stereo replacement
OK anyone with 2007 replace there stereo's? If so did you use the crutchfield wiring harness and is it the same as the 2006? I want to order up a new stereo, but crutchfield hasnt researched the 2007 yet so they do not know if the 2006 harness will work. They are having specials this week and I would like to order, so if anyone can give me some insight i would be happy.
Old Sep 4, 2006 | 11:10 AM
awakeinAZ's Avatar
awakeinAZ
Default RE: 2007 stereo replacement
What are you planning to put in? Did you see the various notes about adding a relay for the amps?
Old Sep 4, 2006 | 01:41 PM
blaven's Avatar
blaven
I replaced mine with a Alpine IVA-W200 and used the harness's from crutchfield. The only problem i had was the antenna was weird on mine. Its like a needle that is in back of the shaker 500 and a hole the size of a needle on the antenna wire. I have yet to find an adapter for this after a few weeks of searching on the internet.
Old Sep 4, 2006 | 01:48 PM
siggy14's Avatar
siggy14
Yes i have read about the voltage regulater for the amps, that i know about, but thanks. I am just gonna be putting in a sony cd/mp3 player, will use stock amps for now but eventually upgrading everything when i have time. I have all the amps and subs already, just need speakers and a Head unit.
ORIGINAL: awakeinAZ
Old Sep 4, 2006 | 01:49 PM
siggy14's Avatar
siggy14
does the alpine have the weird antenna size, or the actuall antenna is different? I also thought crutchfield usually sent the antenna adapter, you might want to contact them.
ORIGINAL: blaven
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
Ford_Dude
Sep 15, 2015 03:25 PM
Webster454
Sep 7, 2015 04:59 AM
TimeLord101
Sep 4, 2015 09:27 AM
