CEL-Check engine light code P0340
Old Sep 12, 2006 | 07:18 PM
LocNar's Avatar
LocNar
Default CEL-Check engine light code P0340
I have been getting a repeating CEL after about 30 min. of driving my '05 stang GT, after it really warms up I guess.
I have a JTL CAI installed with SCT tuner. The tuner displays the code" P0340 CAM POS, S CIR ER 1 S 1"
After doing a little googling it seems it is a "Camshaft Position Sensor" failure.
The car does seems to drive fine, no rough idling/surging, etc.
I went to the Ford Dealer and picked up a new Cam Sensor, about $35 and installed it, both places, with same results after 30-min. of driving, CEL comes on with same code.
Anyone have this happen or know if it is dangerous to keep driving when the CEL keeps coming on with this sensor error?
Thx for any advice/info/tips.
Old Sep 12, 2006 | 07:44 PM
hawgman's Avatar
hawgman
I ♥ Acer
Default RE: CEL-Check engine light code P0340
There have been known alternator issues that will throw the same P0340 code.
Old Sep 12, 2006 | 08:33 PM
LocNar's Avatar
LocNar
thx for the info, i'll to keep an eye/ear out for this, stang has 47k miles on it so ouuta warranty, the alternators fail this soon? I might have to replace? :-(
Old Sep 12, 2006 | 10:24 PM
hawgman's Avatar
hawgman
I ♥ Acer
You got a ton of responses over at the other forum on your question there. Someone even posted the TSB on the issue. You might be able to work something out with your dealer to get it fixed. You don't want to spend $700 for a new alternator I bet.
Old Sep 12, 2006 | 10:35 PM
LocNar's Avatar
LocNar
Thx hawgman for the link, yea got some good info I hope, cept the $700 friggin alternator quote :-(
thx again! any new developments i'l, try and post here
Old Sep 12, 2006 | 10:54 PM
shaners90lxhatch's Avatar
shaners90lxhatch
Dont get too carried away on the alternator. It is a possible cause but you may also have a wiring issue. The engine harness is known to chaff on the variable intake runner linkage on the back of the intake. The harness is attached to the firewall. Your ignition coils may be a source for the same that the alt is. They generate RFI or radio freguency interference when they begin to fail and may not have problems delivering adequate spark, making them that much more difficult to identify. you cant play around with disconnecting them along with the injectors (to prevent cat failure and engine damage) because that will turn on the light and if you don't have the ability to easily pull codes, you won't know when you have made a difference. You will likely run into several aftermarket shops before the problem is really fixed (given unplugging the alt has no affect) and pay more than you should. A good dealer should figure it out in an hour or less leaving you with a $100 bill plus the cost of parts. Sucks to own a new car with problems I know. It can be expensive but it comes with the terrirory. Good luck
Old Sep 12, 2006 | 11:12 PM
moosestang's Avatar
moosestang
ORIGINAL: hawgman
[sm=wtf.gif][sm=WTFsgign.gif] $700, i'm guessing you can't pick that up at discount autoparts. why would an alternator cost that much and is that minus a core charge?
Old Sep 12, 2006 | 11:20 PM
LocNar's Avatar
LocNar
not sure :-( at work currently, gonna make some phone calls tomorrow to dealer. Quick net search netted no alternators available for a '05 stang :-(
i'll post what I find out tomorrow on dealer price.
Old Sep 13, 2006 | 12:05 AM
Newbreedgt05's Avatar
Newbreedgt05
If the alternator is specific to the new stangs, it will be almost impossible to find one at a local parts store. Part stores don't usually stock brand new parts cause they figure the parts will be changed at the dealer under warranty. I found this out when I went to autozone to buy a stock rear shock. They didn't even show a part number for it. The dealer might be the only place to get one. It still shouldn't be $700 though. Maybe including installation.
Old Sep 13, 2006 | 12:31 AM
hawgman's Avatar
hawgman
I ♥ Acer
ORIGINAL: Newbreedgt05
You're right. It shouldn't be. But it is. I got lucky and got one off of fleabay from someone who had parted out a totaled car.
djbigskrilla
Sep 20, 2022 01:04 AM
microgt
Aug 20, 2015 07:12 AM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
