What suspension part do I need?
Old Sep 15, 2006 | 10:55 PM
redfireshaker06's Avatar
redfireshaker06
Default What suspension part do I need?
Maybe it's because I have not had the car aligned yet after the springs so there is some bad camber. After the alignment and this still happens, what will I need? The car got into a grove today on the side of the road and the steering wheel turned with it. Is that bumpsteer?
Old Sep 16, 2006 | 12:15 AM
StreamlineGT's Avatar
StreamlineGT
Default RE: What suspension part do I need?
Bump steer is when you go over a bump and your toe changes. Now that your car is lower, the toe has changed because of the condition. get it aligned. You might need camber plates, but they are a pain to put in. I have em, and I had to modify your struts to install. I still have to have mine aligned too. I'll let you know if you should get camber plates based on if mine needs a lot of adjustment. Probably not though, others have said only a 1/4 degree of negative camber after lowering 1", so it might not be necessary.
67STANGX2
Sep 24, 2015 12:29 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
degner122
Sep 16, 2015 07:09 AM
Sep 8, 2015 11:50 AM
Sep 1, 2015 08:16 PM
