Limited Slip on Automatic GTs
Old Sep 16, 2006 | 11:30 AM
Tri C's Avatar
Tri C
Default Limited Slip on Automatic GTs
The '06 Mustang brochure lists a limited slip rear axle as an option on GTs equipped with an automatic transmission and as standard on those with a manual. I've never seen any ordering information from any source that showed it's availability as an option and don't recall it being listed on any window sticker I've seen.
So what's the story - do automatic GTs have limited slip as standard or as an option or not at all?
Old Sep 16, 2006 | 01:26 PM
Archion's Avatar
Archion
Default RE: Limited Slip on Automatic GTs
I believe it is standard on all gt's, even the final drive ratio is the same for both in 07
Old Sep 16, 2006 | 01:35 PM
281GT's Avatar
281GT
I think Ford has been messing around with the options. I know that on the 05's limited slip was standard on all GT's regardless of manual or automatic. It would be stupid to have a car with 300 hp and no limited slip but I guess they are cutting costs by having as an option on the auto equipped cars now. It's a bad idea. With 300 hp you are going to have a pretty bad traction problem without an LSD.
Old Sep 16, 2006 | 02:42 PM
06GT4RAD's Avatar
06GT4RAD
Well was a puzzling question indeed, when i ordered my car. I took notice of the fact that it listed it as an option in the brochure yet when we placed the order there was no where to order the Limited Slip. My Fleet manager even called Ford Direct and they did not know why it was listed as an option since it is standard equipment in the GT. So we placed the order and the car does in fact have the LS.
Richard
Old Sep 16, 2006 | 02:54 PM
MikeVistaBlue06's Avatar
MikeVistaBlue06
I ♥ Acer
ORIGINAL: Tri C
My '06 with an automatic had a LSD in it. It wasn't mentioned at all on the window sticker. It is a GT coupe premium.
I think all of the GTs have LSD standard.
Thx,
Mike
Old Sep 16, 2006 | 04:18 PM
06GT4RAD's Avatar
06GT4RAD
Mikevistablue i love the Avtar. Do you happen to know if that is avaialble in a T-Shirt and if so Where?
Richard
Old Sep 16, 2006 | 04:52 PM
8cd03gro's Avatar
8cd03gro
ORIGINAL: 281GT
that's insane...i have problems hooking up sometimes without an lsd, and you guys have far more hp, torque, and shorter gearing. never buy a gt without an lsd, no matter what you do. I can't beleive ford would even think of doing that!
Old Sep 16, 2006 | 04:58 PM
gregariousgreg's Avatar
gregariousgreg
The limited slip is standard on all GTs. It's just the 3.55 rear gear ratio that's optional. 3.55 was standard on the 05-06s now it's optional and I believe 3.30 gears are standard.
Old Sep 16, 2006 | 11:58 PM
07GT's Avatar
07GT
True, I just ordered an 07 and the 3.55 was optional, cost me $87
ORIGINAL: gregariousgreg
Old Sep 17, 2006 | 01:45 AM
mustangman02232's Avatar
mustangman02232
all GTs have a t-lok after 87 atleast, maybe even before that,
