Shaker question, please help
Old Sep 24, 2006 | 04:54 PM
redfireshaker06's Avatar
redfireshaker06
Default RE: Shaker question, please help
So the suctions not strong enough to suck the water off of the air box bottom?
Riven02's Avatar
Riven02
ORIGINAL: PullMeOverRed05
First off, the opening within the actual scoop is much smaller than the opening at the front of the scoop and is also located at the top. I believe this is the first defense against water intrusion into the system because most of the water that makes it back that far will fall below the intake tube.
There is almost no way water can make it into the tube because of the reason described above. Also where the hole is that connects the tube to the air box is not at the bottom of the tube (forming a dam) so no water will make it to the air box. I have driven in very heavy rain and I have never had any wayer make it to the box. Even if it did it wouldnt make it to the filter.
Old Sep 24, 2006 | 09:09 PM
Bish's Avatar
Bish
Thanks for all the good questions and answers!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
