Time to Winterize
Old Sep 29, 2006 | 04:24 PM
Riggs007's Avatar
Riggs007
Default Time to Winterize
I started to winterize my stang and i keep thinking im forgeting something this is what ive done so far, im i forgeting anything?
Washed inside/outside, oil/rad fluid change, changed tires back to stock, steel wool in mufflers, wrapped intake with tin foil, took out battery,
filled gas tank
Old Sep 29, 2006 | 04:27 PM
Archion's Avatar
Archion
Default RE: Time to Winterize
Stabilizer in gas tank, by Stabil i think it is.
Old Sep 29, 2006 | 04:32 PM
Riggs007's Avatar
Riggs007
thats what it was, thanks
Old Sep 29, 2006 | 05:05 PM
stratjakt's Avatar
stratjakt
put it on blocks or jack stands to avoid flat spots in tires
Old Sep 29, 2006 | 05:48 PM
Riggs007's Avatar
Riggs007
i put the stock tires on instead, besides wear spots dont last very long at all. At least they dont on my 4x4
Old Sep 30, 2006 | 02:15 AM
BAMFstang's Avatar
BAMFstang
Don't forget to give her a big kiss, re-assure her that you love her
and will be anxiously awaiting spring so you can be together again.
Old Sep 30, 2006 | 03:00 AM
roadrunner1659's Avatar
roadrunner1659
just wondering...why do you wrap your intake with tin foil and why is steel wool put into your muffles?
Old Sep 30, 2006 | 10:28 AM
Archion's Avatar
Archion
incase of mice and such, if he is anywhere near the country, they will be looking for places to stay come winter
Old Sep 30, 2006 | 10:48 AM
Sonic Boom NH's Avatar
Sonic Boom NH
Few other suggestions:
If in a garage make sure to either remove ALL food sources (dog food, cat food, trash etc.) OR insure those food sources are tightly sealed otherwise it will attract mice.
If it’s on a cement slab that has ground directly underneath put down a large plastic tarp on the floor the car will be parked on. Moisture can and will seep up from under the cement slab. The plastic tarp will act as a moisture barrier and prevent moisture from reaching the undercarriage of the car causing rust. If your slab has a craw space underneath like some Cape’s do then the tarp is not really necessary.
From a lot of reading I have done in years it’s not a good idea to put a vehicle on jacks unless you’re going to keep the suspension “loaded”. In other words if you put your jacks under the frame your suspension is just hanging and that’s not considered good for it. What I do is air the tires up to 45 – 50psi. Also as was mentioned even if the radial tires get flat spots they will not stay longer then a few miles after driven. The bias tires were tires that could be damaged by flat spots.
Run the motor and turn the A/C on and then shut the car off while leaving the ventilation on A/C. This will close up any possible entrances into the vehicle through the ventilation thus preventing mice from getting inside the car. Also, insure the windows are rolled all the way up as mice can fit into a space of ¼” or so.
Old Sep 30, 2006 | 11:44 AM
Bish's Avatar
Bish
Good information, everybody.
Thank you!
