Removing lower grill
Old Oct 12, 2006 | 08:11 PM
Playboy06's Avatar
Playboy06
Default Removing lower grill
How do you remove the lower grill?
Any tips?
Old Oct 12, 2006 | 08:14 PM
VnCist00's Avatar
VnCist00
Default RE: Removing lower grill
screwdriver? lol
do u at least know how to take the front bumper off?, i havent seen the lower grill on the inside but take the bumper off and check, then use the tools necessary.
Old Oct 12, 2006 | 08:52 PM
dmhines's Avatar
dmhines
Lay on the ground and look from the back ... it clips on just like the upper grill ..... just yank and it comes off pretty easy .... just don't mess up my grill!
Old Oct 12, 2006 | 09:20 PM
doodad's Avatar
doodad
for some reasion my car doesn.t have lower grill.. wtf????
Old Oct 12, 2006 | 09:59 PM
classj's Avatar
classj
When I bought my car the lower grill was actually loose and had to be popped back in.
Old Oct 12, 2006 | 10:07 PM
petepete's Avatar
petepete
it clips ongotta take th ebumper off
Old Oct 13, 2006 | 11:40 PM
fairlane292's Avatar
fairlane292
It doesn't??? explain????
Old Oct 13, 2006 | 11:45 PM
fairlane292
One wider upper tab over each opening; 2 narrower lower tabs on each side below honeycomb area. (2 upper outer tabs are alignment only and have no tab catch on them). You need to press the tab catch away on each tab as you push or pull the grill out. Once you get one started it gets easier; I wouldn't yank at it; those tabs are easy to break; don't even attempt it outside if its cold.
Old Oct 16, 2006 | 02:27 PM
jimSD63's Avatar
jimSD63
ORIGINAL: Playboy06
Any tips?
Run over an empty 5-gallon plastic water bottle on the freeway and drag it for 1/4 mile. It'll pop right out!
Old Oct 16, 2006 | 02:37 PM
Archion's Avatar
Archion
[sm=funnypostabove.gif]
