CDC Agressive Chin Spoiler install
Old Oct 20, 2006 | 12:40 PM
Sherwood06GT's Avatar
Sherwood06GT
Default CDC Agressive Chin Spoiler install
I have purchased the CDC Agressive Chin spoiler. My question to anyone who has this installed is: can you still use car ramps (the low profile ones) with this chin? I understand the clearance is just a bit over 5". Info would be greatly appreciated.
Old Oct 20, 2006 | 12:49 PM
PullMeOverRed05's Avatar
PullMeOverRed05
Default RE: CDC Agressive Chin Spoiler install
I even have problem with the CDC classic, but I think you will find that with any spoiler.
Here is a trick that I use. Get a good piece of 2x6 or 2x8 lumber (only need a foot or 2).. Place the lumber towards the bottom of the ramp on each side. That will in effect lower the required clearance and allow your car to drive up the ramp in a smoother incline than just the ramps alone.
Just make sure you check that the lumber is still there when you back off the ramps or you will catch the spoiler on the way down.. ouch
Old Oct 20, 2006 | 12:57 PM
bl1nk's Avatar
bl1nk
ORIGINAL: Sherwood06GT
We have a pair and tried to run my car up on them and the spoiler touched while the wheel was still about 4 inches away.
Old Oct 20, 2006 | 01:00 PM
Kaldar142's Avatar
Kaldar142
just use a jack
Old Oct 20, 2006 | 01:04 PM
Sherwood06GT
I like the 2x8 idea. The jack suggestion is off topic, but thanks. Either way, I WILL be installing the Chin Spoiler. It is just the coolest chin spoiler out there!!!
Old Oct 20, 2006 | 03:15 PM
Archion's Avatar
Archion
The 2x8 idea is similar to the ramp extenders you see at most parts stores for the low profile ramps, and they latch onto the ramps.
Old Oct 20, 2006 | 04:06 PM
WhiteStallion06's Avatar
WhiteStallion06
I purchased the side exhaust kit from cervini and i need something to even out the front and i dont like the cervini front that much i dont wanna change my grill....im still deciding between the cdc classic or agressive they both look good tho.
Old Oct 20, 2006 | 04:09 PM
PullMeOverRed05
ORIGINAL: Archion
I haven't seent these, but I figure they would be the same principal. The left over wood is just cheaper if you already have it!
Old Oct 20, 2006 | 04:11 PM
Archion's Avatar
Archion
Oh exactly!!! BTW I still use the wood, its handy.
Old Oct 20, 2006 | 05:27 PM
bl1nk's Avatar
bl1nk
ORIGINAL: WhiteStallion06
Maybe this will help.
[IMG]local://upfiles/37638/967639AFDD29433187AF6F5771391145.jpg[/IMG]
