WHY?
Old Nov 1, 2006 | 07:11 PM
mAnYsTyLeS's Avatar
mAnYsTyLeS
Default WHY?
I was at the gas station yesterday filling up so I decided to test the vehicle check system (or whatever it's called). I left the gas cap off and then went in my car to do the test and it said my fuel cap was "OK." Why? It was obviously off.
Old Nov 1, 2006 | 07:16 PM
Rupp's Avatar
Rupp
Default RE: WHY?
I did this same test and it didn't throw that code either.
Old Nov 1, 2006 | 07:37 PM
Haze28's Avatar
Haze28
Default RE: WHY?
It takes a while before it throws a code, try turning your car on with the cap off for a couple minutes.
Old Nov 1, 2006 | 09:17 PM
saltzy's Avatar
saltzy
Default RE: WHY?
There's no little button like on your door or trunk to tell the computer your gas cap is off, it can tell that the cap is off by the change in pressure (or lack thereof) in the fuel system. You need to have the motor running and even then it won't be instantaneous.
Old Nov 1, 2006 | 09:44 PM
04stangman's Avatar
04stangman
Default RE: WHY?
ORIGINAL: saltzy
Well said!
