caster camber plates
Old Nov 4, 2006 | 06:56 AM
Dont Try's Avatar
Dont Try
Default caster camber plates
HELP!! I just ordered the Eibach sportline lowering springs and the alignment kit from RPMOutlet.com. Do i need caster camber plates as well?? If so where can I find them? I have been looking with no luck. I just want to make sure I have everything to get it done when they get here. Thank You!
Old Nov 4, 2006 | 12:15 PM
CrazyAl's Avatar
CrazyAl
Default RE: caster camber plates
Goog luck with RPM outlet. They have a very poor reputation regarding customer service around here!
You don't need camber plates specifically. But you do need some method of correcting the camber. I suggest eccentric bolts (aka camber bolts). They work just as well and are much cheaper.
You also may want to consider an adjustable panhard bar and adjustable lower control arms.
There are many threads about lowering and suspension correction afterwards. Try searching
baddog671
Jul 26, 2016 01:20 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
mdg
Oct 1, 2015 07:04 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
