05 people I need a help
Old Nov 28, 2006 | 05:49 AM
mow's Avatar
mow
Default 05 people I need a help
What does it mean ( FAIL SAFE ENGINE MODE )
What is my problem with this stang?Coz i have no idea
Old Nov 28, 2006 | 06:02 AM
DuFFMaNN's Avatar
DuFFMaNN
Default RE: 05 people I need a help
My cousin got the same thing when his aftermarket Throttle body got stuck wide open. It goes into this mode with something like this happens so you don't die, or mess up the engine more.
Old Nov 28, 2006 | 06:12 AM
mow's Avatar
mow
i have the stock Throttle body just the K&N airfilter..... any way is there any way to solve this issue ?
am going to dyno the car to check the A/F !!!
Old Nov 28, 2006 | 08:39 AM
abs's Avatar
abs
Hi,
I faced the same problem earlier with the K&N filter.
Check the filter bolt with the throttle body for air lockage (Mine did came off because I did not bolt it tightly)
Old Nov 28, 2006 | 02:49 PM
JDBullitt's Avatar
JDBullitt
I had that problem last winter. It turned out to be my throttle body sensor.
Old Nov 29, 2006 | 02:35 AM
mow's Avatar
mow
thx guys for this info ill take the car to the workshop ( dayno ) to c what is really going on
Old Dec 2, 2006 | 02:37 AM
mow's Avatar
mow
the cods: with Diablo predator
1- p1000
2- p2106
3- p2135
I don’t know what to do is there is any thing should I look into ?
Old Dec 2, 2006 | 08:42 AM
KdF's Avatar
KdF
ORIGINAL: mow
1- p1000
2- p2106
3- p2135
P-1000 = OBD readiness test not complete
P-2106 = TAC system forced limited power
P-2135 = TPS/Pedal position Sensor/Switch A/B Voltage correlation
This is what my computer program says it is. It is for 2003 and older cars , but it should be the same anyway.
Old Dec 2, 2006 | 08:45 AM
KdF's Avatar
KdF
here`s another idea for ya.....
Use your diablo to clear the codes.
Unhook your battery for 15-30 min and see if it does it again.
If so......DEALER TIME!
Old Dec 2, 2006 | 10:48 AM
GT John's Avatar
GT John
ORIGINAL: KdF
+1
baddog671
Jul 26, 2016 01:20 PM
Dokilar
15
Oct 16, 2015 08:13 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
popsotto
Sep 28, 2015 06:58 AM
