LCA
Old Dec 21, 2006 | 01:45 AM
chirostang's Avatar
chirostang
Default LCA
I don't exactly understand what the lower control arms do. Is it a worthwhile mod? Which brand is the best? How do you install these things? If I had them, how would my driving experience change? Thanks ahead of time.
Old Dec 21, 2006 | 01:47 AM
chirostang's Avatar
chirostang
Default RE: LCA
Also, would I need other suspension upgrades or are LCAs enough?
Old Dec 21, 2006 | 01:51 AM
CrazyAl's Avatar
CrazyAl
Default RE: LCA
LCAs are a part in your suspension. The rear suspension, specifically. These are bars that connect the rear axle to the body of the car. These, along with the UCA, are what transfer the force from the rear axle of the car to the body, which pushes the car forward when you accelerate.
The problem with the stock ones is that they flex, and most importantly, so do the stock rubber bushings in the LCAs. This is what causes wheelhop under hard acceleration. It contributes to your rear tires spinning instead of grabbing when you accellerate hard in a low gear. It also contributes to poor handling when you hit the corners hard.
Some LCAs are adjustable. This is so that you can correct the pinion angle of your rear end if you lower the car or if you install a 1-pc driveshaft.
Is it worthwhile? YES YES YES YES. As a commercial once said, "power is nothing without control". If you can't put your HP to the pavement, what's the point?
What's the best brand? This is up for debate, but in my opinion, it is BMR...specifically the welded steel ones. Some brands like Steeda sell these made of billet aluminum, but I would avoid those. They are expensive and heavier than the tubular steel ones. And furthermore, the aluminum ones have been known to break under hard use.
You can expect better traction and better handling with this mod.
Arwing's Avatar
Arwing
Default RE: LCA
ORIGINAL: chirostang
Depends on what you are looking for...
Make sure to read this thread. https://mustangforums.com/m_1696246/tm.htm
What would we do without crazyal
Old Dec 21, 2006 | 01:54 AM
CrazyAl's Avatar
CrazyAl
Default RE: LCA
Read these threads:
https://mustangforums.com/m_2184423/tm.htm
Old Dec 21, 2006 | 01:59 AM
bl1nk's Avatar
bl1nk
Default RE: LCA
ORIGINAL: Arwing
Drive traction-less Mustangs [8D]
Old Dec 21, 2006 | 03:11 AM
ANBAUTO's Avatar
ANBAUTO
Default RE: LCA
Im using the Steeda Cromolly tubualr ones and i like them alot
Old Dec 21, 2006 | 03:27 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: LCA
Thanks for the treads CrazyAL. Relly helped clear things up!
Old Dec 21, 2006 | 05:12 PM
chirostang's Avatar
chirostang
Default RE: LCA
Hey CrazyAl... I forgot to mention that I have a vert. Does that change anything?
Old Dec 21, 2006 | 05:14 PM
CrazyAl's Avatar
CrazyAl
Default RE: LCA
Not as far as the LCAs are concerned. Good luck!
