Clunk when engaging first gear...
Old Dec 28, 2006 | 05:17 AM
James Cole's Avatar
James Cole
Default Clunk when engaging first gear...
Hey all, well I have this problem, when I am at a dead stop and engage 1st gear I can hear this clunk that seems to be coming from the driveshaft... is this normal? and yes I do have the clutch all the way in.
Thanx in advance.
Old Dec 28, 2006 | 05:48 AM
Sprzout's Avatar
Sprzout
Default RE: Clunk when engaging first gear...
You're not the only one having this problem.
I've been hearing a clunk when I shift from 1st to second, and only then...I posted about this the other day and it seems that this is part of a 2 piece driveshaft problem, and only happens at lower RPMs.
Old Dec 28, 2006 | 01:41 PM
James Cole's Avatar
James Cole
but what is kind of weird is that when you engage first gear with the clutch all the way in there isnt any movement in the driveshaft ( I hear the clunk before I even start letting go of the clutch to get going)
Old Dec 28, 2006 | 01:52 PM
bascho's Avatar
bascho
With a working clutch fully depressedthe only "clunk' noiseyou wouldhear going into gearis a bad syncro-mesh. It's also possiblethe clutch is slipping and the "clunk" is the gears not being completely stationary when you engage. Does this happen in any othergear?
Old Dec 28, 2006 | 01:57 PM
James Cole's Avatar
James Cole
apparently just in first.
Old Dec 28, 2006 | 05:48 PM
James Cole's Avatar
James Cole
Update....
It only happens once in a while, what it always happen is clunk/grind in second gear only when you make the change 1st to 2nd when first is below 2.5k rpms...
Old Dec 28, 2006 | 07:18 PM
jay00f4's Avatar
jay00f4
These cars have more clunks and noises then you can imagine.
Old Dec 28, 2006 | 08:05 PM
Kaldar142's Avatar
Kaldar142
haha i took my honda friend for a ridei n my mustang and he thought my tranny was going to fall out frm all the sounds it was making, i just told him thats the sound of power lol
Old Dec 28, 2006 | 10:04 PM
backinblack06's Avatar
backinblack06
Mine makes a clunking also sometimes when going into first I don't believe it's the driveshaft though. I think it's the synchros or something in the tranny slamming in because I can feel the vibration up through the shift ****.I just wrote it off as being normal, but who knows I'm a newbie to manual tranny's. If It's not normal I'd like to know to. As of know I have a nice little to do list togive to my dealer so Iguess one more problem can't hurt lol.I've learned that the first few shifts after a cold start are like trying to shift through a brick wall though....I think that is normal because the fluid sunk to the bottom or may be cold !?
Old Dec 28, 2006 | 10:28 PM
moosestang's Avatar
moosestang
Yours is probably the sound of an improper pinion angle or your LCA's not torqued enough.
Have you been to the alignment shop yet?
ORIGINAL: Kaldar142
Thunderball
15
Nov 22, 2015 11:49 PM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
guitarman376
Sep 30, 2015 05:54 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
