suspension question
Old Dec 30, 2006 | 08:04 PM
peteway's Avatar
peteway
Default suspension question
when lowering your gt (05-07) with the ebiach pro kitsprings and tokiko shocks/stuts do you need caster camber plates? do you need anything else to correct the camber or do you not need to worry about that when using just the pro kit.
I don't have a spring compressor and my local shop wants $300 to do the install so I may at least do the rear myself at least...
Old Dec 30, 2006 | 08:30 PM
06GT4RAD's Avatar
06GT4RAD
Default RE: suspension question
Get yourself a set of camber bolts. Stangsuspension.com carries them. You should be able to go to your local Auto Parts store and rent a strut compressor which is all you need to install the fronts.
Richard
Old Dec 30, 2006 | 08:33 PM
peteway's Avatar
peteway
Thanks.
Old Dec 30, 2006 | 08:38 PM
Black3vGT's Avatar
Black3vGT
You don't need a compressor to do the install, I just did mine today without one. You'll have to get an alignment after, and they should be able to return the camber back without the bolts.
Old Dec 30, 2006 | 08:47 PM
leepinlen's Avatar
leepinlen
did mine last week, free rental of strut compressor at autozone. did not need the camber bolts after realignment from ford dealership.
Old Dec 30, 2006 | 09:43 PM
moosestang's Avatar
moosestang
ORIGINAL: Revlefty
How? There is no way to adjust camber without the bolts, unless i'm missing something obvious.
+1 on not needing a spring compressor, especially if your going to install the tokico struts.
Gene K
Oct 21, 2015 11:37 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
degner122
Sep 16, 2015 07:09 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 1, 2015 08:16 PM
