Vortech blower installed and dyno'd
Old Dec 31, 2006 | 07:52 PM
lieu910's Avatar
lieu910
Default Vortech blower installed and dyno'd
Here are my dyno results from my Vortech s/c
Only supporting mods are.
CMCV delete plates
Mac Prochamber w/cats and Mac Axle back mufflers
467.49hp @6200 RPM
411.34TQ @4600 RPM
This is a pretty conservative tune. With better fuel pump, I could make more.
Old Dec 31, 2006 | 08:15 PM
Norse1974's Avatar
Norse1974
Default RE: Vortech blower installed and dyno'd
Not bad at all Bro!Now go out & whoop up on somebody!
Old Dec 31, 2006 | 08:23 PM
ANBAUTO's Avatar
ANBAUTO
nice numbers, making more than my procharger setup. i wonder if it because you have the delete plates and i cant wait to get those as well. What were your A/F's like?
Old Dec 31, 2006 | 08:30 PM
Kaldar142's Avatar
Kaldar142
have any sound clips of your car?
Old Dec 31, 2006 | 09:17 PM
lieu910's Avatar
lieu910
ORIGINAL: ANBAUTO
A/F is at 11.78 average. I'm running 10 psi. and have the aftercooler set-up. I doubt the delete plates did much at all, but I figured they were good insurance.
Old Dec 31, 2006 | 11:33 PM
ANBAUTO's Avatar
ANBAUTO
well your running more psi that myself so thats where the extra power is coming from. Nice numbers tho! also was the A/F measured at the tailpipe or before the cat?
Old Dec 31, 2006 | 11:51 PM
lieu910's Avatar
lieu910
ORIGINAL: ANBAUTO
Not sure where the measurement was taken. I take ityou are running 8 psi or so. Figure a pound of boost is about 10rwhp. We had to tune my car down some. I had a sharp drop off in fuel pressure at about 5,900 rpm. With a boost a pump we will be able to squeeze another 15-20 hp out of it.
Old Jan 1, 2007 | 01:21 AM
forensicsteve's Avatar
forensicsteve
Great numbers especially for a conservative tune. Does your tuner recommend you try for anymore with stock internals? I use mystreet tune for daily driving. Always interesting to know what other tuners recommend for their mustang clients.
Old Jan 1, 2007 | 02:51 AM
ANBAUTO's Avatar
ANBAUTO
Yea im only running 7-8psi and the fuel pump setup is the twin focus pump. heres my dyno
https://mustangforums.com/m_2460541/tm.htm
Old Jan 1, 2007 | 04:21 AM
rwdfan's Avatar
rwdfan
I would not advise putting in much more boost. When you get near the 500hp mark on these engine those connectings rods tend to go boom. Any more and I would look into some H beams or I beams, something rated for more power. They actually use a hyperecutic process or soemthing...trying to remember what its called exactly. Or was it the pistons.....Ya may want to check into that...can't remember now, anywayz, the v6 uses better internals and can nearly support as much power as the v8 with boostbefore needing new internals. SO whatever...losing my thought. Good numbers and good luck!
