side stripe removal
Old Jan 3, 2007 | 11:39 AM
jim01028's Avatar
jim01028
Default side stripe removal
I'm wondering how to remove the side stripes on my 05. I have seen several posts where people mention that in their mods /descriptions, so I guess it can be done.
Old Jan 3, 2007 | 11:42 AM
chrisc65's Avatar
chrisc65
Default RE: side stripe removal
I waited for a hot day and took a razor and started on one end. Once you get it started - it peels right off.
Good luck!
Old Jan 3, 2007 | 11:56 AM
CaptainAmerica's Avatar
CaptainAmerica
I had the dealer remove mine as part of the "deal" - it is my understanding that they use a special extra hot blow dryer to easily peel them off. (I do that with all of my cars, i hate decals other than big bold white stripes down the middle )
Old Jan 3, 2007 | 12:07 PM
jim01028's Avatar
jim01028
thanks for that info guys, now I have to wait for a hot day in New England, those stripes might be on there for another couple of months lol. I didn't think too much about them until I saw other stangs with the color matched side skirts and no stripes and realized how much "cleaner" they looked.
Old Jan 3, 2007 | 12:52 PM
MrSandman's Avatar
MrSandman
Been thinging about this too.. but mine are starting to grow on me... gives it that retro matchbox car look (see sig)... now all I need is tires with raised white lettering...
ORIGINAL: jim01028
Old Jan 3, 2007 | 01:03 PM
LegallyTorchRED's Avatar
LegallyTorchRED
You can also use "decal remover", it won't hurt the paint, is non-toxic. Available at most NAPA's. Sprays on, and wait a few mins, and presto, peels right off.
Old Jan 3, 2007 | 05:13 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
If you use a hair dryer that will work as well! Start at one end and gently peel the corner and heat up the vinyl ahead of it and it should just slowly peel right off with no residue afterward! If there is residue than go get some goo-gone (real name of product) and it works wonders...than procede to waxing to protect the area
Old Jan 3, 2007 | 05:30 PM
raubt's Avatar
raubt
I was rinsing my car off with a hot-water pressure washer and one of the side stripes started to come off accidentally. So basically: heat. Hot water, hair dryer, etc. I'd be careful with the razer plan though, seems very easy to scratch if you're not extra careful.
Old Jan 3, 2007 | 06:07 PM
fairlane292's Avatar
fairlane292
+1
I would not go anywhere near the car with a razor (no need)
Im in MA and this weekend looks like it may be close to 60. Have the side facing the sun for a while, then use the hair dryer as indicated above (no heat gun). I haven't tried 'decal remover' but if temps are low and you can't wait until spring, it may be worth a try.
Old Jan 3, 2007 | 06:59 PM
Ry05Stang's Avatar
Ry05Stang
Hello fellow New Englander, I'm here in Providence, RI and I just took my side stripes off 2 days ago. It was around 50 degrees out... I went outside with a blowdryer and an extension cord and went to it. I just put the blow dryer on one end for about 20 seconds and it peeled right off with my finger nails and was easily pulled right off. There's nothing to it
