ebay mod
Old Jan 7, 2007 | 03:12 AM
pxdig's Avatar
pxdig
Default ebay mod
What do you guys think about this? is it worth the cash? how hard to install?
Thanks.
http://cgi.ebay.com/ebaymotors/05-07...67424922QQrdZ1
Old Jan 7, 2007 | 04:45 AM
Caution's Avatar
Caution
Default RE: ebay mod
I personaly dont think that it's worth that much.... as far as the install goes -- it's easy & and will only take you like 30 minutes.
Old Jan 7, 2007 | 05:28 AM
shockme76's Avatar
shockme76
Not a good idea unless it comes with a tuner which it doesn't. Put that on and it will mess with your air to fuel ratio. Without a matching tune for that intake your car will run like crap and you risk damaging it. I would find an air intake and tuner combo. It's going to cost more but it's worth it. I haven't seen the K&N's packaged with a tuner and i don't see how they yealed HP gains without proper retuning.
Old Jan 7, 2007 | 05:58 AM
djmac95's Avatar
djmac95
+1 ^
Old Jan 7, 2007 | 06:20 AM
howarmat's Avatar
howarmat
s197 Junkie
Pony up the dough and get a C&L with tuner!
Old Jan 7, 2007 | 06:32 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I have one but it is for the V-8! It was an easy install and had no problems with it of what so ever. I had a tune put into it after the kit was installed but that was not a nessary step just a wanted one as you don't have to tune the intake like the others. Just breathes better without drastically changing the A/F ratio.
Old Jan 7, 2007 | 11:49 AM
my77stang's Avatar
my77stang
yeah if you dont wanna shell out for a high end cai and tuner these are great cause the diameter of the tube is the same as stock, so no air/fuel ratio headaches - that being said you should prolly just save up and buy the better one - i didnt hold out and now i will be buying again. =(
if you really wanna go cheap there are k&n knockoffs on ebay for less than half the price (which is what i got) and they are identical to the k&n typhoons
Old Jan 7, 2007 | 01:27 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Im not a fan of these intakes. You can put it on without a tune, but thats only because the air goes through a **** straw around the mass air flow. I don't really see how you are going to get all that much more air flow. I would go with a tuner kit. Been there done that but with a S&B intake. Now its all good with the JLT.
Old Jan 7, 2007 | 01:43 PM
my77stang's Avatar
my77stang
agreed, which is why i'll end up buying a second (better) CAI
the cheaper ones DO offer some gains, i think the typhoon is like 9 HP vs. 15 HP of a higher end model.
Old Jan 8, 2007 | 12:58 AM
ZZLEGEND's Avatar
ZZLEGEND
has anyone tried the granatelli cold air intake?
