Midas and Flowmasters!
Ok, Peep this! I wentto Midas this morning and got 2 Flowmaster 40 series, Installed I paid $350. In about 2 hours I was on my home happy as a ****. As usual I am hauling *** and I hear a rattle comming from the back, common sence tells me it must be my mufflers. I get home and look under my car and I see that one of the exhaust hangars on the drivers side muffler has broke off. WTF????????? Not even 1 hour old!!!!! So I start back to midas and the other hanger broke off I get out and my muffler is hanging next to the ground. The weld holding the hanger to the muffler. Luckally I had a wire hanger in the trunk and rigged the muffler to make ot back to midas! I was in and out in 1/2 hour after the repair. The mechanic said the weld broke because the welder is a piece of ****, the weld would not penitrate through the muffler skin. So to make a long story short, so far it has been a pain the *** but they sure do sound sweet!
You should not have had to have anything welded. The bad thing is you probably got a bubble gum weld job even by the guy who fixed itthe second time. Around the weld will be the firstplace to rust you might consider touching up the weld with high temp. paint.
ORIGINAL: 04stangman
The mufflers did not come with hangar brackets on them from the factory?So, if they are not to be welded how else put them on there? just wondering?
http://www.completeexhaust.com/produ...oducts_id=1192
I have the same mufflers on my Marauder. They sound good on the 4.6 MOD V8, don't they? [8D]
Might have to do what you did and buy another set, this time for my GT.
