GT500 Gauges???
Old Jan 10, 2007 | 01:59 AM
StangNeWbieDJB's Avatar
StangNeWbieDJB
Default GT500 Gauges???
Does anyone know how I can change my setup to be just like the GT500's? I hate having my tach on the left...The only time I look at the speedo is when I'm passing a highly "poe poe" populated area...or when I'm in 5th already...[sm=gears.gif]
They did it right with the GT500...I really want my tach on the right...HELP!
Old Jan 10, 2007 | 07:05 PM
StangNeWbieDJB
Default RE: GT500 Gauges???
NOBODY??????
The Tach is on the right in the GT500...NO one elsewants this on their car??? I'm shocked!!!
Old Jan 10, 2007 | 07:09 PM
Ruffnuts's Avatar
Ruffnuts
The gauge panel is a one piece so in order to swap them you would need a new gauge panel, also the wire harness isnt long enough to criss cross the guages not to mention the the solid piece that supports all the hardware behind the guages.
Old Jan 10, 2007 | 07:26 PM
s2k's Avatar
s2k
The Rpms are different in the GT500 soI assume it would notwork anyway.
Old Jan 10, 2007 | 07:37 PM
07GT's Avatar
07GT
ORIGINAL: StangNeWbieDJB
NOBODY??????
To tell you the truth I don't see why it would make any difference. On my car one is as visible as the other. Is it because you want the tach more towards the center of the car? I would prefer the additon of a shift light in the tach though.
Old Jan 10, 2007 | 08:57 PM
StangNeWbieDJB
The reason is I look at the tach more than the MPH and when I'm getting on it I can't see how close I am to redline...it's frustrating!!! maybe ashift light might be a cheap solution...but I was hoping since they are about an inch away from one another can't I just switch them??? I guess I'll have to reserch this elsewhere...[&:]
Old Jan 10, 2007 | 11:24 PM
BigDave's Avatar
BigDave
I hardly ever look at the tach...listen to the engine and use a shift light. But when the stereo is real loud I sometimes realize my tires are spinning in first gear when the shift light comes on prematurely.
Old Jan 10, 2007 | 11:44 PM
imyy4u's Avatar
imyy4u
re-adjust your seat and you should be able to see both while you are driving. either that or adjust the tilt on the steering wheel. left side, right side, shouldn't make any difference at all.
Old Jan 11, 2007 | 12:11 AM
FordDude's Avatar
FordDude
NOBODY??????
The tach is on the right side of my Mustang. Oh wait did you mean a S197 Mustang? I really do not see what the problem is. I can see the speedo and tach equally well. fd
Old Jan 11, 2007 | 03:17 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
nice lol 1+
