Shaving antena
Old Jan 13, 2007 | 07:42 PM
SlinkyBMX's Avatar
SlinkyBMX
Default Shaving antena
I am interesed inremovingthe antena. I have seen the antena's that install into the top of your windshield. Does anyone know where these are available. And has anyone done this and have pictures? Does the wiring show, or is it all hidden. Also how hard is the install? Thanks alot!
Old Jan 13, 2007 | 07:53 PM
Norse1974's Avatar
Norse1974
Default RE: Shaving antena
Yeah,I would be interested in this as well.I already just took the intena off the car & looks 100% better.I always use the cd player so it was no loss.
Old Jan 13, 2007 | 08:25 PM
xbone's Avatar
xbone
Cut the antenna down with a hacksaw then stick something cool on the tip, like dice, ball, whatever, or just round the tip off and leave it bare.
Old Jan 13, 2007 | 08:31 PM
odiaz's Avatar
odiaz
The install is super simple, takes about 30 minutes. I wrote up instructions, here they are:
http://www.cherod.com/mustang/HowTo/...a%20Delete.htm
The trick is that you need to provide power to the antenna. You only want the antenna to have power when the radio is on. I found the best source for power was pin2 of the J1 connector on the Shaker 500/1000. This ping provides power only when the radio is on. use a vampire tap to connect the antenna power lead to this wire.
I had the antenna hole welded shhut and filled in by my local body shop. The paint was a perfect match. You can't tell there was ever an antenna on the fender.
Here's a picture:
[IMG]local://upfiles/15215/6F578B8DB19648D4AFEB1EE462EEAC10.jpg[/IMG]
Old Jan 13, 2007 | 10:14 PM
wishIhada5.0's Avatar
wishIhada5.0
Is it true that it can be cut in half with a hacksaw and put the original little black ball back on?
Old Jan 13, 2007 | 11:40 PM
panzermk2's Avatar
panzermk2
UHG Garbage Motors used to think windshield antenas were all "THAT" they s@ck.
I would have a hard time beleiving they have gotten any better although based on those install pics it does seem to be a fare cry from the thin defroster style windshield antenasof old
Old Jan 14, 2007 | 12:52 AM
fairlane292's Avatar
fairlane292
I have Tune Trapper (non powered ) under dash. It's pretty good but I'm not into pretty good. I think in early spring I'm gonna put a power unit in. stainless with small almost flush stainless base. Goes up when rad on, down when off. ...just like we had in the 60s and 70s; have done two so far (61 fairlane, 65 vette) reception awesome in both.
[IMG]local://upfiles/24316/49E93F94AA7E4221B25885264FCF5AD3.jpg[/IMG]
Old Jan 14, 2007 | 01:18 AM
Mister Roper's Avatar
Mister Roper
ORIGINAL: wishIhada5.0
Yes.
Old Jan 14, 2007 | 01:24 AM
s2k's Avatar
s2k
Since we are talking about antennas does anyone have a picture of a black 8 inch antenna since i just ordered one?
Old Jan 14, 2007 | 11:39 PM
odiaz's Avatar
odiaz
ORIGINAL: fairlane292
NO, DON'T do it Fairlane. Your car is gorgeous. Don't drill a hole in the fender. The amplified Metra antenas are actually extremely good. I get better reception with it then I did with the stock antenna (from what I remember, I installed the Mettra antenna shortly after I got the car.) Give the Metra antenna a try before you drill a hole in your car.
