Hurst Shifter Question
Old Jan 15, 2007 | 07:15 PM
acascianelli's Avatar
acascianelli
Default Hurst Shifter Question
Ever since I sat in the Shelby GT at NAIAS, I've been wanting to put a Hurst shifter in my 07 GT. However, I do have a few questions about it.
1) Once installed, is there ANY possibility of causing damage to the transmission.
2) Will it void the warranty on the powertrain.
3) Why are some other shifters better, should I consider any others?
4) My Mustang is a daily driver, will a Hurst shifter cause any problems/annoyances.
Old Jan 15, 2007 | 07:35 PM
ZZmustang's Avatar
ZZmustang
Banned
Default RE: Hurst Shifter Question
1. Installed incorrectly anything can cause damage to something else.
2. It will void warranty on the shifter, unless installed incorrectly, then it will void the warranty on anything the service writer can convince you is wrong because you put a shifter in.
3. Shifters are made of steel or aluminum, better is subjective, and you should ALWAYS consider all others
4. The problem it will cause is the length of the shift will be shortened, and that would be annoying if you like long shifts.
Hears a question for you , How far is up? which way is that way? at the end does it start over? sorry, I just had to.
Old Jan 15, 2007 | 07:36 PM
mustangman2424's Avatar
mustangman2424
I ♥ Acer
1) No
2) No
3) I wouls consider the saleen shifter because it is really smooth, the hurst shifter is really notchy
4) No
Old Jan 15, 2007 | 10:31 PM
1BADD05's Avatar
1BADD05
love the hurst shifter and recommend it!
Old Jan 15, 2007 | 10:33 PM
acascianelli
ORIGINAL: 1BADD05
What about it being notchy?
carid
Jul 8, 2016 09:55 AM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
firecoyote
Sep 27, 2015 02:37 PM
Sep 16, 2015 07:53 PM
Webster454
Sep 7, 2015 04:59 AM
