backspace...bolt pattern ?
Old Jan 21, 2007 | 09:06 PM
TonySteppsTang's Avatar
TonySteppsTang
Default backspace...bolt pattern ?
Anyone know from how much to how much backspace and bolt pattern can fit on a 2006 Stang
Old Jan 21, 2007 | 09:14 PM
Arwing's Avatar
Arwing
Default RE: backspace...bolt pattern ?
Not really sure
Old Jan 21, 2007 | 09:16 PM
jerseystang07's Avatar
jerseystang07
I'm sorry, but [sm=WTFsgign.gif]are you talking about???
Old Jan 21, 2007 | 09:26 PM
raubt's Avatar
raubt
The bolt pattern is 5 bolts, and I think by "backspace" he probably means wheel offset, ie, where the actual face of the wheel sits relative to the width of the rim (so you can fit the brake calipers and all that fun stuff behind the wheel.)
Not really sure though...
Old Jan 21, 2007 | 11:24 PM
06GT4RAD's Avatar
06GT4RAD
Bolt pattern is 5x4.5 backspacing depends on what width wheel you plan on using Anywhere from 34mm to 45mm I think if memory serves me correctly.
Richard
Old Jan 21, 2007 | 11:55 PM
TonySteppsTang
ok thanks so would 5 x 4.75 10"Wide fit okay.
Old Jan 22, 2007 | 12:10 AM
retfr8flyr's Avatar
retfr8flyr
ORIGINAL: TonySteppsTang
No it will not. As posted you need 5x4.5 for the bolt pattern. Some 10 inch wheels will fit and some wont it depends on the offset and the size. A 10 inch wide 17 inch wheel will not fit without modifications for clearance, an 18 or higher will fit with the correct offset.
Earl
Old Jan 22, 2007 | 12:43 AM
drbobvs's Avatar
drbobvs
Yes 5X4&1/2 and the stock 17's OFFSET is 45mm. When comparing new wheels to stock worry about OFFSET not backspacing.
Old Jan 22, 2007 | 12:51 AM
JBD3482's Avatar
JBD3482
Would these fit a 06 v6? http://www.americanmuscle.com/anthracite-fr500-wheel-17x9.html
Old Jan 22, 2007 | 12:57 AM
drbobvs's Avatar
drbobvs
Yes, but they will stick out about 1&3/8" more than stock.
