DTC question
Old Jan 22, 2007 | 08:28 AM
e_pad's Avatar
e_pad
Default DTC question
What does P061B stand for.
Car is an 06 GT.
Thank you
Old Jan 22, 2007 | 11:42 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: DTC question
P061B
Internal Control Module Torque Calculation Performance
Description
Indicates a calculation error occurred in the powertrain control module (PCM).
Possible Causes
[*]Unplugged motor, circuits shorted to voltage[*]TAC motor open, unplugged motor, circuits shorted to voltage[*]TAC motor stuck open or closed[*]Mass air flow (MAF) sensor concern[*]Throttle position (TP) sensor concern[*]Output shaft speed (OSS) sensor concern[*]Turbine shaft speed (TSS) sensor concern[*]Anti-lock brake system (ABS) concern[*]PCM damaged
Old Jan 22, 2007 | 05:56 PM
e_pad's Avatar
e_pad
Well, that narrows it down
It happened when the traction control kicked on real hard. It was wet and came loose in second gear. I have since just turned of Trac. Hate that crap anyway. hopefully it won't happen again.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
