fidanza clutch 4.3 series
Old Jan 24, 2007 | 05:54 PM
Dont Try's Avatar
Dont Try
Default fidanza clutch 4.3 series
anyone out there running a fidanza clutch series 4.3 with theirAluminium flywheel?? you like it?? planning on usin it just for daily driving have some heavy mods already tore up 2 stock clutches
Old Jan 24, 2007 | 06:06 PM
CrazyAl's Avatar
CrazyAl
Default RE: fidanza clutch 4.3 series
What kind of mods do you have? That is a pretty agressive clutch.
Old Jan 24, 2007 | 06:18 PM
Dont Try's Avatar
Dont Try
well i am planning ahead aswell. plan on getting a supercharger. right now i have full 3 inch exhaust LT headersCAI xcal2 pulleys, putting in 4.10 gears , comp cams stage 3, composite driveshaft and this fadanza 4.3 clutch and their AL flywheel. think i should go with the 3.2 series??
Old Jan 24, 2007 | 06:31 PM
CrazyAl's Avatar
CrazyAl
A clutch that strong is going to be really "Grabby" on the street and is huge overkill if you don't have any sort of power adder. In fact, if you've already burned up two normal clutches without forced induction, then I would look to your driving style. The clutches should last a heck of a lot longer than that (unless you're driving an insane number of miles)
Anynway, if you are planning on big power in the future then a clutch like that wouldn't be a bad idea, though I would suggest a Spec Stage 3+ instead. They hold up to 900 ft-lb of torque and are much more street-friendly than the higher stage Fidanzas.
By the way, if you are getting SC don't bother with the agressive cams. Stage 3s will run HORRIBLY with a supercharger. The overlap period is too long, and your intake charge will get blown out the exhaust port. The best cam for forced induction is stock.
Granatelli Sales
Mar 25, 2016 08:01 PM
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
Art161
Sep 9, 2015 10:33 AM
