$225
Old Jan 24, 2007 | 11:02 PM
ohsixgt1217's Avatar
ohsixgt1217
Default RE: $225
Well if you have a cai, and no tune, you're most likely running lean, therefore a tune is almost neccissary. Save up another 200 bucks and either get yourself a tuner from brenspeed or get a custom one if theres a local shop around you. Running too lean = very bad news for your engine if you get on it.
Old Jan 25, 2007 | 12:03 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Default RE: $225
What kind of CAI...I know K&N makes one with no tune needed. You wont run lean on a CAI designed for no tune.
Old Jan 25, 2007 | 12:07 AM
04stangman's Avatar
04stangman
Default RE: $225
I have a K&N, I have good luck with those on 3 other stangs~
Old Jan 25, 2007 | 01:06 AM
ohsixgt1217
Default RE: $225
Your k&n cai = good mod....you k&n cai with tune = best mod you'll get on your car before any forced induction. Seriously, save 200 more dollars and get the tune. Not only will you feel more power but the throttle response is amazing, that and it will run much smoother. Just my .02
Old Jan 25, 2007 | 01:09 AM
Arwing's Avatar
Arwing
Default RE: $225
ORIGINAL: sailing220
Forgive my ignorance as I am a complete beginner when it comes to mods and basically cars in general, but can somebody explain a tune?
http://www.brenspeed.com/images/9400.gif
Old Jan 25, 2007 | 02:53 PM
sandy's Avatar
sandy
Default RE: $225
Can you tune and still use regular gas, or does it mean you have to go to premium?
Old Jan 25, 2007 | 06:02 PM
2oo5stang's Avatar
2oo5stang
Default RE: $225
You can get a tune for, depending on your area, 87,89,91, or 93 octane. If you want to save money on gas, install the 87 tune. If you feel like using 93 tune, empty the tank, install 93 octane, install programmer and upload the 93 tune. Or 91.
for the 225 bucks, maybe a mid pipe or pulleys. I would save up and get a bigger diameter CAI and Tune. The K&N CAI tubing goes to stock diameter before and alittle after the mass air(so no tune is needed)and then opens up. Get a CAI that's all the way opened up and install the tune. The AirRaid CAI, you stick the MVT in the CAI opening and it makesthe mass air sectionsmaller so you don't need a tune, but when you get the tuner, you take out the MVT so the CAI flows more (4in diamter all the way) then install your tune.
Old Jan 26, 2007 | 06:40 PM
TElke1's Avatar
TElke1
Default RE: $225
springs? Front lip spolier?......maybe those are the things I want
Old Jan 26, 2007 | 07:27 PM
Daniel60's Avatar
Daniel60
Default RE: $225
Two hundred dollars come on man you know better.[&:]
Old Jan 26, 2007 | 07:31 PM
Haze28's Avatar
Haze28
Default RE: $225
My advice would be to save that $225 and wait till you can get something that is worth spending the money on.
