offfset?
Old Feb 1, 2007 | 02:03 AM
mdcorny's Avatar
mdcorny
Default RE: offfset?
Mine are 20's, but the offset should still be the same.
30mm front
42mm rear
[IMG]local://upfiles/59606/425E1FB9FB5C4F2B8DB5BF2B37420436.jpg[/IMG]
Old Feb 1, 2007 | 12:28 PM
2k05gt's Avatar
2k05gt
mine are +42 offset
[IMG]local://upfiles/25187/797C983453D443B7BB608351719FEFB1.jpg[/IMG]
[IMG]local://upfiles/25187/02EDD7B33D0143838279DF06ABA0E135.jpg[/IMG]
Old Feb 1, 2007 | 12:37 PM
drbobvs's Avatar
drbobvs
Listen to his request everyone, he wants the wheels to be in even with the fender. Yes, stock 8"-8.5" wide wheels for '05+ is 45mm, therefore if you want to keep "in-line" with stock with a 9" wheel you need about 35mm offset to ensure caliper clearance. To get out to the fender you need about 25mm in offset for a 9" wheel. About 35mm for a 10" wheel.
Some of you have say 275mm wide tires which stick out past the rim more and give the illusion of the wheel sticking out more too. When viewing the pics Kaldar, keep your eye on the location of the rim.
Old Feb 1, 2007 | 04:25 PM
mdcorny's Avatar
mdcorny
Check out this link, it talks about flush with fenders.
http://www.ssinserts.com/index.php?m...roducts_id=739
The Defiance wheel is the ONLY aftermarket wheel designed exclusively with the correct and enhanced offsets required to keep the wheels flush with the fenders for improved styling. 30mm Front and 42mm Rear. (Will not stick-outside fenders or tuck inside fenders as most aftermarket wheels do.)
Old Feb 1, 2007 | 06:21 PM
likemike99's Avatar
likemike99
it really depends on your wheel and tire. flush rims vs deep dish would require different sizes. the best way is to actually measure it on your car
