Axleback alignment help!
Old Feb 12, 2007 | 10:08 PM
bboren's Avatar
bboren
Default Axleback alignment help!
i was just wondering whats the best way to adjust an axleback thats hanging a little too low. i know i probably have to mess with the hangers to move it, but do i need to just whack the hanger with a hammer to move it? or do i need to heat the hanger up and bend it? any ideas would be appreciated. i just didnt want to take it off and try anything until i know i can do something that works.
Old Feb 12, 2007 | 10:10 PM
kenthicken's Avatar
kenthicken
Default RE: Axleback alignment help!
No need to bend the hanger. Loosen the bolts on the h-pipe clamp in the middle of the car and adjust as needed. It doesn't seem like it will work on the face of it, but it does work.
Don't break out the hammer!
Old Feb 12, 2007 | 10:38 PM
bboren's Avatar
bboren
oo i never thought of that because ive never even messed with that section of the exhaust. ill see if it works or not
Old Feb 12, 2007 | 10:42 PM
bboren's Avatar
bboren
i cant seem to get the bolts on the h-pipe clamp loose and i have no way of lifting my car so i kinda just have to reach under there.... with no success
Old Feb 12, 2007 | 10:50 PM
drbobvs's Avatar
drbobvs
Well. I used the old school method on mine. Take a large box wrench and hold it in a verticle position and slide the box end over the rear most hanger rod of the muffler. Make sure the top of the box wrench offset angles toward the back of the vehicle. Pull the bottom of the wrench toward the front of the vehicle, this will bend the rear of the hanger rod of the muffler down, thus lifting the muffler up.
Old Feb 12, 2007 | 11:55 PM
mjm2007's Avatar
mjm2007
I have the Bassani axle back exhaust-when I installed it I had to grind the alignment tabs off the stock pipes because the Bassani mufflers did not have cutouts for the alignment tabs. If this is your problem it will not let the mufflers slip on to the pipe far enough and it won't hang properly.
Old Feb 13, 2007 | 12:04 AM
bboren's Avatar
bboren
mine are as far on the pipe as they can go. its just my right muffler hangs down about an inch lower and i couldnt get it to go any higher jiggling it around.
Old Feb 13, 2007 | 12:31 AM
edgespeeder06's Avatar
edgespeeder06
yea mine was hittin against my rear axle. i squeezed under the car and fixed it as much as i could but it still bangs when both wheels go in a dent a road when im going fast, i dunno if it does any damage but im going to have ford fixed lol
Old Feb 13, 2007 | 01:38 AM
davisr014's Avatar
davisr014
I would try loosening it back up have someone hold it higher then you want it while you tighten it. When you let loose it should be good. that is how I adjusted mine. Hope it helps
Old Feb 13, 2007 | 04:59 PM
kenthicken's Avatar
kenthicken
Get some ramps for $40 or so at the auto parts store and back up on to them. Should give you clearance to work in the middle. Trust me, the "H-pipe clamp trick" will work.
