Another question on tires...
Old Mar 7, 2007 | 08:24 PM
Haze28's Avatar
Haze28
Default Another question on tires...
I just bought new wheels and am in the search for tires. I stopped at the local Discount Tire and told the guy that I was looking to put a 295/45/18 on the 10.5" wide wheels in the back. He tells me i'm crazy if I think it will fit. I have other people telling me I can run a 315 on the rear. Can someone shed some like on this little problem i'm having. I want to go as wide as possible without having to do any modifications to the rearend. Thanks in advance.
Old Mar 7, 2007 | 08:36 PM
TheDarkPath's Avatar
TheDarkPath
Default RE: Another question on tires...
295s would have fit my 10inch rears but I went with 285. If you look on the tire manufacturer's website, they'll usually give you wheel width ranges that certain tires will fit. A friend of mine is running 315s on a 10.5 inch rim and they work nicely.
Old Mar 7, 2007 | 08:52 PM
Black3vGT's Avatar
Black3vGT
10.5" is more then wide enough for 295s, and will fit 315 just fine.
Old Mar 7, 2007 | 09:09 PM
GT4HUTCH's Avatar
GT4HUTCH
what's your offset and backspace on the wheels. they will fit on the rims no doubt but may stick out from the side of the car.
Old Mar 7, 2007 | 09:12 PM
GT4HUTCH's Avatar
GT4HUTCH
also that tire size is going to be 28.452" tall. just something to consider. If you are wanting to stay close to the stock tire height. a 295/40/18 is closer.
Old Mar 7, 2007 | 09:18 PM
Ford_Dude's Avatar
Ford_Dude
ORIGINAL: GT4HUTCH
incorrect it would be 23.226378 inch diameter
http://www.geocities.com/rlh_115/tires.xls
Old Mar 7, 2007 | 09:32 PM
Haze28's Avatar
Haze28
I can't find a 295/40/18, just 295/45 and 295/35. I'd rather have to much than not enough on the side wall, especially in my area. We have some really rough roads hear in Chicago. As for the wheels, they are the correct offset and backspacing for the 2005+ Mustang, unless the guys at stage3motorsports are lying to me. I'm going to test fit the wheels tomorrow to see if they are the right ones.
Old Mar 7, 2007 | 09:57 PM
Menace's Avatar
Menace
ORIGINAL: Ford_Dude
ORIGINAL: GT4HUTCH
Actually the tire will be 27.29, which is pretty close to the stock height of around 27. The question is, what type of tire are you going to be running? I'm going to go with a 285 as it's the only thing offered in All-weather.
Old Mar 7, 2007 | 11:53 PM
Scotty07's Avatar
Scotty07
My vote for the 295/45/18 is 28.3 to 28.5 inches.....
Old Mar 8, 2007 | 12:42 AM
GT4HUTCH's Avatar
GT4HUTCH
Where so those numbers come from?
295mm x .45(aspect ratio...45% the width of the tire) = 132.75mm
132.75mm / 25.4(mm per inch) = 5.226377953"
5.226377953" x 2(side wall height top and bottom...or left to right) = 10.45275591"
10.45275591 + 18"(rim diameter) = 28.45275591"
That is the mathematics. If not my calculator is smurfed up.
HUTCH
