RAPTORIZED!!!!!!
Old Mar 9, 2007 | 11:38 PM
blueherd02gt's Avatar
blueherd02gt
Default RAPTORIZED!!!!!!
A shift light should be the mod of the year!!!!
[IMG]local://upfiles/38668/600E0D4D84E84C3E82E00029384411DE.jpg[/IMG]
Old Mar 9, 2007 | 11:55 PM
Stkjock's Avatar
Stkjock
Retired Mod
Default RE: RAPTORIZED!!!!!!
that's great... how was the install?... did u check to see how different the air flow is?
I was thinking of adding on myself... and sticking it in the bottom of the tach gauge...
Old Mar 9, 2007 | 11:58 PM
blueherd02gt
I almost never use my a/c or heat....unless my wif'e is riding with me. The install took 30 mins, but I had verything I needed. I pushed it as far back as possible because I figured I'd need it more at night [:-]
Old Mar 10, 2007 | 12:05 AM
undefeated's Avatar
undefeated
ORIGINAL: blueherd02gt
Clever!
Stkjock's Avatar
Stkjock
Retired Mod
thanks.... very cool
Old Mar 10, 2007 | 01:30 AM
mlcrycc's Avatar
mlcrycc
Boy, that little sombitch puts out some light doesn't it?? I'm going to do one in about three weeks, right after I install the MGW shifter..[sm=wootwoot.gif][sm=wootwoot.gif]
I think I am going to mount mine up top, either in the middle of the map lights, or to the left of that upper console......
Thanks for the pic!! Oh, and by the way, where did you buy, and how much, if you don't mind....
Thanks,
Mike
Old Mar 10, 2007 | 01:49 AM
blueherd02gt
www.raptorperformance.com$85+$7shipping=$92 that goes perfect with a short throw shifter. I thought 92 bucks was a bunch for a tach light but wow every standard shift car needs one.....especially these cars. I set it up for 5500rpm so when I see it I can react into my shift @6200rpm....[8D]
Old Mar 10, 2007 | 01:54 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Great work and thanks for the pic! Good idea wiht placement of the raptor! J
Old Mar 10, 2007 | 08:10 AM
redfireshaker06's Avatar
redfireshaker06
Awesome, where did you run your power wire?
Old Mar 10, 2007 | 01:21 PM
blueherd02gt
I used the add-a-circuit (at any auto parts store) with a .5 amp fuse to the fusebox on the passenger side
ORIGINAL: redfireshaker06
