Need instructions for Steeda Shifter Bushing
Old Mar 21, 2007 | 12:29 PM
androdz's Avatar
androdz
I ♥ Acer
Default Need instructions for Steeda Shifter Bushing
Does any1 have the steeda shifter bushing instructions? My dog ate them and I am dead serious -.-. Some1 please scan them if you can, I asked steeda to fax me some but can't really see the pictures.
Andrew
Old Mar 21, 2007 | 12:34 PM
stangmann's Avatar
stangmann
Default RE: Need instructions for Steeda Shifter Bushing
not sure about steeda, but on hurst, you reuse the bushings from the stock shifter.
Old Mar 21, 2007 | 01:23 PM
androdz's Avatar
androdz
I ♥ Acer
I ordered the polyurethane bushings alone. Since our shifter the shifting is done not directly but thru a linkage the less play the shifter has the better the shifts will be.
Andrew
Old Mar 21, 2007 | 01:30 PM
Goody625's Avatar
Goody625
ORIGINAL: stangmann
My hurst came with urethane bushings. Just had to reuse the metal bushing spacer on the shifter arm...I, too, am not sure about the Steeda....
Good luck
Old Mar 21, 2007 | 02:51 PM
Riven02's Avatar
Riven02
ORIGINAL: androdz
Andrew
I dont think mine came with instructions but it is real easy. Just unbolt the shifter and replace the bushings.
Here are some pics of when I did mine.
Old Mar 21, 2007 | 05:24 PM
androdz's Avatar
androdz
I ♥ Acer
Can ya check?
Old Mar 21, 2007 | 10:40 PM
howarmat's Avatar
howarmat
s197 Junkie
Old Mar 21, 2007 | 11:18 PM
aircare84's Avatar
aircare84
Mine didn't have any directions either. Easy swap once you unbolt the shifter. Only thing you need to do is bend down the metal 'tab' holding in the stock retangular aft bushing to slide it out & then rebend it up after you install the replacement. You'll see what I mean when you unbolt the shifter assy.
Old Mar 21, 2007 | 11:40 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: aircare84
Yep, +1. And that tab can be a PITA if you are not removing the shifter all the way.....[:@][:@]
Mike
Old Mar 22, 2007 | 12:46 AM
androdz's Avatar
androdz
I ♥ Acer
Thanks!
