Lowered with 24mm offset???
Old Mar 22, 2007 | 05:58 PM
Stealthy's Avatar
Stealthy
Default Lowered with 24mm offset???
I have tried searching with no real answer. I currently have gt500 wheels on my car with a 24 mm offset and 255/45/18 BFG KDW. I've seen one guy who was running +24mm offset shelby razors with a 255/35/20 tire and steeda lowering springs, which according to the tire size estimator is pretty much exactly the same size as my setup. I want to put the steeda ultra springs on mine but am obviously worried about rubbing. Is there anybody out there that can give me some current info on whether or not this setup will work???? Thank you in advance.
Old Mar 22, 2007 | 07:09 PM
Justin_R's Avatar
Justin_R
Default RE: Lowered with 24mm offset???
Dont know about your question, but do the tires stick with 255's?
Old Mar 22, 2007 | 08:28 PM
Stealthy's Avatar
Stealthy
Are you talking traction or poke?
Old Mar 22, 2007 | 11:58 PM
Justin_R's Avatar
Justin_R
ROFL! I just saw what I said, I meant to say do the tires stick out, LOL! Sorry.
Old Mar 23, 2007 | 12:24 AM
howarmat's Avatar
howarmat
s197 Junkie
I have FRPP springs which is almost a 2 inch drop and 265/35 on my GT500. You can lower you car with no problems as those springs are not going to drop you as much as mine did. I would maybe go wider and a 40 instead of 45.
Old Mar 23, 2007 | 12:43 PM
Stealthy's Avatar
Stealthy
Yes they do stick out the sides a little bit, but I think it looks really good. That is my concern though....if I lower it I'm afraid I may rub since they stick out. HOWARMAT.....are your wheels 24mm offset? They don't look like they stick out at all??? Am I wrong?? I used the tire size estimator to check the dimensions on a 275/35/18 and I would have created an extra inch and a half of wheel gap........so if I lowered it with say, the Eibach pro kit, I would still have more wheel gap than before I lowered it. Thats why Iwent with the 45 instead of the 35.
Old Mar 23, 2007 | 04:26 PM
howarmat's Avatar
howarmat
s197 Junkie
You should have the 50 offset and not the 24. With the 24 they will stick out quite a bit more once you get wider. As for the gap. There is quite a bit less than i had before changing the wheels and springs.
Old Mar 23, 2007 | 06:22 PM
Justin_R's Avatar
Justin_R
Could you send me pics please!! You are the only one with the same offset that is running 255's were running 245's and I was afraid to go to 255's cause I heard theyll stick out alot, so if you could post some pics that would be awesome!
ORIGINAL: Stealthy
Old Mar 23, 2007 | 11:46 PM
Stealthy's Avatar
Stealthy
You have already seen 255 with 24mm offset. Cylyne, a.k.a. "cluless girl", is my wife. But here is the pic anyway with my car too!! VW FTW!!
[IMG]local://upfiles/62605/B5B5F80FBA9B47BC838A69938D761AC7.jpg[/IMG]
[IMG]local://upfiles/62605/36CA500546994482B994DA43E41D550E.jpg[/IMG]
Old Mar 23, 2007 | 11:48 PM
Stealthy's Avatar
Stealthy
some more pics....
[IMG]local://upfiles/62605/2512797A83D44E05A283ECB61164C65A.jpg[/IMG]
[IMG]local://upfiles/62605/7501725D5D3147029DF9FE9435EFEB25.jpg[/IMG]
[IMG]local://upfiles/62605/52DDCDD4631447A7B4F1C667F838EF40.jpg[/IMG]
