GT 05 heders problem
Hello,
I have a problem. Will buy one GT 2005 next week and there is a little problem with it.
Seller has changed to heders and a new exhaust system as I understand.
On the new system there is only place for "one" "O2" sensor as I did understand. And there is four?!
He is now getting "check engine" and when pluging in OBD reader he get error on the "O2" sensors.
I dont understand why buy a system that is not correct but what evere.
Is this something that can be fixed? Or is a new system the only thing?
I don“t know what mark/model there is on the new system but maybe someone can help me either way.
I know he did bought it from Summit and seller says that Summit has told him, that the check engine light should not be on, so I dont know.
Thank You
Daniel From Sweden
Thank You
Daniel From Sweden
The CEL will come on unless you either get a tuner and dial out the O2 sensors, or get MIL Eliminators.
http://www.mileliminators.com/
Ok so the car will run great without all the sensors connected?
What type of tuner whould you prefer? Xcal 2? Diablo?
So there is no strange thing that there is only 1 connection at the exhaust?
I have ben thinking about the XCal 2 seems to be a good thing.
Thanks so mutch!
Thanks so mutch!
boy its hard to believe that a dealer would have this problem. If you are in the states and in mass for example, your car will fail inspection due to the o2 sensors not being on. also if your check engine light is on.The 05 gt has four sensors, one on the one in the driver side header two in the cats and one right above the passenger side cat. My nieghbor is a state trooper and i ask him questions on legal stuff and i asked about getting rid of the o2s and he would inpound a car that didnt have them, i do know this is true in cali also, so just be careful and make sure it works when you take delivery
Shorties do not require O2 sensor removal on the driver's side, The O2 on the pass side should have one bung welded to the New header for reinstall of the sensor. (The driver's side stays on the stock H-pipe)
(I mave the Driver/Pass info reversed as it has been two years since I installed my long tube Hookers).
Long tubes haveports for the O2 sensors on aft aft-most tube, and again at the collector.
I assume you have shorties since you mentioned ONE sensor.
Having shorties the only things that can go wrong is the prev owner did not re-connect the pass side O2 sensor. Or worse, could not get it disconnected (A ***** to get to)and removed the sensor without disconnecting the wiring first (twists the crap out of it and can cause wires to break and short out).
But if you have Long tubes:
1. The prev owner did notget Mil Eliminators for the check Engine issue. (Having Cat O2Eliminators tricks the aft sensors).
2.The Prev oner may have left one of the fwd sensors disconnected. (a real ***** to disconnect and connect + causes blood loss too).
3. The fwd O2 sensors have to stay operational (feed back to the computer rich/lean) the aft-of the cats can be turned off with a tuner. feed back to the computer for Cat operation only.
4. You can buy a code reader at Walmart for $60.00.
5. If you want to stay somewhat legal (Install aftermarket Cats in the Y area just fwd of the H-pipe section, you'll have to intall O2 cable extensions too.) While this is not CARB approved it will get you thru emissions sniffer testing. JBA sells the complete H-pipe with cats.
6. You need to post the codes you get, since they are different on the front sensor VS aft.
Hope this helps.........
Well, now the car is mine.
I now knew some more about the problem.
The forward 02 sensors is mounted on exhaust system, and the 2 rear 02ones are not mounted. BUT the cables are connected to the two connected ones.
The CEL light is on.
I have bought a SCT Xcalibrator 2 with a custom tune for my application.
Shipping time to Sweden is about 14 days so I need to wait now.
Do you gys think that will fix my problem.
This is done to the car, but it is never tuned.
Afraid Open Intake System - Summit Partnr: AID-450-172
Borla Cat-Back- Summit Partnr: BOR-140135
JBA Cat4ward Long Headers - Summit Partnr: JBA-6675SJT
Car runs smoth most of the time, sometimes the car not realy want but after a wile it roars.
Thanks
Daniel
Thanks
Daniel
