Drop Spindles
Old Apr 10, 2007 | 12:47 AM
red stangguy's Avatar
red stangguy
Default Drop Spindles
Found these thought some of you would rather get this and then some shorter springs for the rear, looks to be less work but cost more.
Features:
- Direct OEM replacement
- 1.25" front drop without using lowering springs
- Spindles cost more than lowering springs but do much more
- Eliminates need to adjust caster/camber & for bump steer kits
- NO LOSS in ride quality, superior handling
- HD ductile iron construction
- Durable powder coated finish
- Includes all necessary hardware
- Installs in approximately 2-4 hours using basic hand tools
Front - 1.25' Drop
GM-FS0507
GM-FS0507
$423.75
[IMG]local://upfiles/64087/76BA7CDC02F2428DAD74AAFC916C4833.jpg[/IMG]
Old Apr 10, 2007 | 12:57 AM
LegallyTorchRED's Avatar
LegallyTorchRED
Default RE: Drop Spindles
My question is,. if you are lowering 1 1/4" without changing springs, the OEM spring is being compressed 1 1/4"more thannormal. Doesn't this affect ride quality and handling ?
Old Apr 10, 2007 | 01:01 AM
red stangguy
The spring is not changed at all the drop spindle raises the wheel upward to make it look drop it does not affect the geometryof the factory allinment.I had these on on a S10 chev pickup they worked great and they were easy to put on.
Old Apr 10, 2007 | 01:28 AM
LegallyTorchRED
Ok, I understand, the wheels go up 1 1/4", the chassis goes lower, and the OEM supension is unchanged. So the spindle is "offset 1 1/4" ? It would be an up, rather than drop, wouldn't it ? (on the spindle)
Old Apr 10, 2007 | 03:26 AM
INTRUDER's Avatar
INTRUDER
can you post a link to the site ?
Old Apr 10, 2007 | 07:24 AM
moosestang's Avatar
moosestang
ORIGINAL: LegallyTorchRED
Yes. The point where the tire mounts is moved up 1 1/4 inches compared to the stock spindle. Drop spindles have been around forever. A lot of lowered trucks use them.
Old Apr 10, 2007 | 10:24 AM
red stangguy
Here is a link to the web site http://www.stillen.com/product.asp?i...PIN01&c=SU
Old Apr 10, 2007 | 04:52 PM
RodeoFlyer's Avatar
RodeoFlyer
NO NO NO NO NO NO NO!!!!
you don't want those. I wont even go into details. Others in the know should be chiming in anytime now. Those are Granatelli spindles [:'(]
Gene K
Oct 21, 2015 11:37 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
winner99
Sep 30, 2015 07:04 PM
zanemoseley
Sep 6, 2015 12:58 PM
