Recallibrating Speedo
Old Apr 11, 2007 | 10:41 AM
Mpaint99's Avatar
Mpaint99
Default Recallibrating Speedo
Can I recalibrate my speedo and tach with my SCT tuner? Got my 410 gear installed and speedo is way off.
Old Apr 11, 2007 | 11:23 AM
mightymouse's Avatar
mightymouse
Default RE: Recallibrating Speedo
You should be able to I don't have one yet but from what i read on the tuners they will do that.
Old Apr 11, 2007 | 01:32 PM
Scotty07's Avatar
Scotty07
Yes you can with the SCT2. You can adjust for gear ratio as well as tire rev's per mile. I adjusted both since I changed both gear and tiresand am within 1/2 MPH @ 60 MPH according to GPS.
Old Apr 12, 2007 | 12:04 AM
Mpaint99's Avatar
Mpaint99
Was it very difficult or brainless? I haven't messed with my tuner other than my intial download. I also now have 18 inch tires along with the new gear.
Old Apr 12, 2007 | 11:03 AM
05CLASSIC's Avatar
05CLASSIC
Good question!!!! I am getting gears soon and I went through my SCT and did not see info about changing gear ratio. Where do I look??
Old Apr 12, 2007 | 11:08 AM
Mpaint99's Avatar
Mpaint99
Scotty07 noted it had to be a SCT2 tuner. Luckily I have that. I will go threw mine today. If I cant figure it out I'll ask Brenspeed and then post how.
Old Apr 12, 2007 | 06:13 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Do the 4.10 gears screw up divability? Do you lose top end or have to take off in secod? because that was my life in my fox body with 4.30's and I dont want to go through that again. How does it improve performance? Is it woth it? And most important , which brand and price? Please!!!!!
Old Apr 13, 2007 | 10:16 AM
Mpaint99's Avatar
Mpaint99
I've only been able to drive it home. The next day we had a snow storm! Driving home felt great. Rpms werent bad at all.
Old Apr 13, 2007 | 03:13 PM
05CLASSIC's Avatar
05CLASSIC
What about the speedo-xcal2. Everything work out? And how?
Old Apr 14, 2007 | 12:04 PM
Mpaint99's Avatar
Mpaint99
Yes, you can reset your speedo with the SCT 2 tuner. It was easy. I did call Tom at Brenspeed. All you do is go to the custom tune you picked and hit select. Next the tuner will ask you to enter parms. Hit select and arrow down to Gear ratios and put in 410s hit select. It will reset your tune and reload your computer. Took 5 minutes.
