Corsa install, HELP!!
Old Apr 25, 2007 | 08:34 PM
brandon97's Avatar
brandon97
Default Corsa install, HELP!!
I got the passenger side in about 20 mins without jack stands or adjusting the h-pipe clamp. Now I moved over to the driver side, loosen the clamp on the muffler and the bolts on the tail pipe and I can't get the A/B to come off the pipe.....what do I do now? I have loosen the clamp all the way....without stands I can't get to the clamp in the middle of the car. is this the problem?
Old Apr 25, 2007 | 08:47 PM
jcw's Avatar
jcw
Default RE: Corsa install, HELP!!
spray it down with some wd40 (weisel ****) let it sit and soak for about 10 minutes then tap firmly not wail on it with a lead shot hammer while try to lightly twist at the muffler. may take two or three shoots of wd to seap into the union.
Old Apr 25, 2007 | 09:10 PM
brandon97's Avatar
brandon97
Thanks...I'll go out and try that!!
PS: I know I'm not very mechanically talented, but how important is the torque wrench? Can I just tighten them really good
Old Apr 25, 2007 | 10:43 PM
Aziraphale's Avatar
Aziraphale
If you don't have the lead hammer, you can also put a 2x4 block on the entrance to the stock muffler and give it a few love taps that way to try and loosen it up. +1 to twisting too.
EDIT: I hope you read TacoBill's howto first https://mustangforums.com/m_3104526/tm.htm
Old Apr 25, 2007 | 11:06 PM
brandon97's Avatar
brandon97
I did read his post...it was very helpful. I finally finished my project....only 3 short hours later!! Most of that time was spent trying to get that one side to decide to loosen for me....Thanks for your help.
TW
Old Apr 25, 2007 | 11:50 PM
Aziraphale's Avatar
Aziraphale
Good, and how do you like them? I'm thinking of pulling the trigger tomorrow on a pair.
EDIT: Just saw your answer in the Corsa A/B post.
mtgldr
Feb 3, 2024 09:00 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
