HELP WITH OCTANE BOOST
Old May 2, 2007 | 01:19 PM
C_yru_s99's Avatar
C_yru_s99
Default HELP WITH OCTANE BOOST
I am looking for a good product to increase gas octane from 91 to 93 any suggestions on addetives??
Old May 2, 2007 | 01:21 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: HELP WITH OCTANE BOOST
93 oct gas??
Old May 2, 2007 | 01:25 PM
C_yru_s99's Avatar
C_yru_s99
Yes 93 octane gas i do not live in an area where it is available so i have to buy addetives increasing 91 to 93..
Old May 2, 2007 | 01:30 PM
05 Mustang GT's Avatar
05 Mustang GT
Good post, I have the same problem here in SLC. No 93 octane gas available. I checked with the local spped shop, the only thing they had was 100+ boost.
Old May 2, 2007 | 01:32 PM
howarmat's Avatar
howarmat
s197 Junkie
Why do you need 93.....you can use 91 for whatever you need.?
Old May 2, 2007 | 01:40 PM
C_yru_s99's Avatar
C_yru_s99
I need 93 octane because my car is tuned for 93 NOT 91
I just purhcased some 104 + extreme octane boost so ill see how that goes
based on my resent research should get me some where around 92.8
Old May 2, 2007 | 01:58 PM
hawgman's Avatar
hawgman
I ♥ Acer
You are going to jack up your car using that crap.
If you need to use some sort of octaine booster, use Torco or nothing. Do a search on just about any board and you will see that octaine booster will mess up the plugs in these cars. Torco is the only thing I would recommend, period.
Old May 2, 2007 | 02:26 PM
MrSandman's Avatar
MrSandman
Have the tuner mail you a 91 octane tune. You can get one from most of the tuners out there. That's a hell of a lot safer than adding that crap to your gas.
ORIGINAL: C_yru_s99
Old May 2, 2007 | 02:39 PM
Jokeurmnd's Avatar
Jokeurmnd
so what i'm reading here is not to use octane in a bottle regardless of what level octane you need? because i was thinking about doing the same thing.
Old May 2, 2007 | 02:52 PM
Getaway's Avatar
Getaway
What hand held tuner do you have?
I would just pull timing from the 93 octane tune myself. In the Predator, pulling 2* of global timing will take your 93 down to 91. Where it says install or modify tune, select modify. Go to global spark, and subtract two. Push escape until you are back to the install/modify screen, and select install tune. It will install the modified tune.
