Gentex Mirror install
Old May 9, 2007 | 12:06 AM
mike3000's Avatar
mike3000
Default Gentex Mirror install
Hey guys,
I read a lot of the write ups on the installation and they are great. I know you runs the wires from the a pillar to the fuse box for power and then to the mirror. The wires in theA-pillar are hidden and they are hidden in the headliner, but what i dont understand is how they are hidden from the A-pillar to the fuse box? Do you remove the part of the dash?
Also once you run temp sensor wire through the firewall, how is the wire hidden from the firewall on its way up to the a-pillar?
Any help would be appreciated.
Old May 9, 2007 | 12:37 AM
mlcrycc's Avatar
mlcrycc
Default RE: Gentex Mirror install
Maybe this will help a bit??
[IMG]local://upfiles/13557/FBE0CE1B55BF47EFB1479F9675B9B577.jpg[/IMG]
Old May 9, 2007 | 12:44 AM
mike3000's Avatar
mike3000
Perfect, thanks. So I guess you remove the kick panel as well?
ORIGINAL: mlcrycc
Old May 9, 2007 | 12:47 AM
mlcrycc's Avatar
mlcrycc
You are correct. Loosen the door sill by pulling straight up, then remove the kick panel. There is a plastic pin that extends from the door sill, down through the end piece of the kick panel.
Mike
Old May 9, 2007 | 12:51 AM
howarmat's Avatar
howarmat
s197 Junkie
nope....this is the way i did it....
http://www.reverendbiker.com/
Old May 9, 2007 | 10:38 PM
mike3000's Avatar
mike3000
Thanks, I looked at your website and it is great, but I can't find the grommet in the engine bay firewall. I have a rubber flap, but no grommet. Where is it?
Old May 9, 2007 | 10:58 PM
howarmat's Avatar
howarmat
s197 Junkie
hehe....you have to remove the battery. It is down pretty low towards the middle of the compartment.
Old May 10, 2007 | 02:13 AM
User 113021's Avatar
User 113021
I'm using this guide for when I hardwire my radar detector in.
mtgldr
Feb 3, 2024 09:00 PM
tmdm
May 2, 2021 02:49 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
mdj89
Sep 8, 2015 10:40 PM
