Question about rims
Old May 15, 2007 | 04:45 PM
Brian_Zinchuk's Avatar
Brian_Zinchuk
Default Question about rims
I already searched the forums, but couldnt get my question awnsered. I'm trying to buy 19"s for my stang because 18"s are to small and 20"s look to big. The problem when Im looking at all these 19"s, nobody states what kind of car they fit on. How can I tell if a certain wheel will fit on my stang?
Old May 15, 2007 | 04:54 PM
northy_polk's Avatar
northy_polk
Default RE: Question about rims
you need to look at the bolt spacing and make sure it's 5x4.5 or 5x114.3. also look at the offset to make sure it will fit on our cars. stock offset is 45 mm, so stay in that range. this post might help https://mustangforums.com/m_3067833/tm.htm. also, do you wantstaggered rims[wider in the back than the front]? some folks go 8-9 inches wide in the front and 10 inches wide in the rear, or other variations. this link will help you get an idea of what to look at when shopping: http://www.bigcustomwheels.com/info_specs.jsp
ah, yes Rodeo, thank you for that correction.
Old May 15, 2007 | 04:58 PM
RodeoFlyer's Avatar
RodeoFlyer
Northy that's 114.3.......
Go to RossMustang.com. Those are 19" wheels on his car. i believe he sells them
Old May 15, 2007 | 09:44 PM
Pantera72's Avatar
Pantera72
18's are too small? Have you ever seen 18's on a S197 in person? It looks freakin awesome.
Old May 16, 2007 | 03:46 AM
Brian_Zinchuk
To much sidewall on the tires.
Old May 16, 2007 | 08:50 AM
Jens07stang's Avatar
Jens07stang
Pantera, That's one awesome looking car you have there. What brand are your wheels?
Old May 16, 2007 | 08:13 PM
Jens07stang
BTW, I think 18" is plenty big enough.
Old May 16, 2007 | 08:39 PM
Stkjock's Avatar
Stkjock
Retired Mod
ORIGINAL: Brian_Zinchuk
then lower your car and get lower profile tires.... 275/40 as an example
keep in mind the bigger rim/tire will slow your car a bit as well...
Old May 17, 2007 | 12:40 AM
Pantera72's Avatar
Pantera72
ORIGINAL: Jens07stang
Jen, the wheels are the 18x9 & 18x10 deep dish chrome bullitts from www.americanmuscle.com. Tires are Nitto555's: 295/45/18 in back and 255/45/18 on front.
Old May 17, 2007 | 12:43 AM
Pantera72's Avatar
Pantera72
I was going for the oldschool "raked/jacked up"look instead of the "in the weeds" look that everybody else has. I wanted to be unique
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
