About to do differential fluid.. need tips
Old May 19, 2007 | 02:39 PM
ohnoesaz's Avatar
ohnoesaz
Default About to do differential fluid.. need tips
Any tips?
I just take the cover off correct? Then I wipe off the old stuff, put on new sealant and put the cover back on. Wait a really long time and then fill to the fill plug level. Or is there a different place to set the level at?
Well, anyways, thanks ya'll.
Old May 19, 2007 | 03:32 PM
ohnoesaz's Avatar
ohnoesaz
Default RE: About to do differential fluid.. need tips
Please...
Old May 19, 2007 | 04:25 PM
RodeoFlyer's Avatar
RodeoFlyer
that's about it. make sure to put in plenty of friction modifier. be prepared - the stuff smells like crap
Old May 19, 2007 | 04:40 PM
ZZmustang's Avatar
ZZmustang
Banned
Put full synthetic oil and a friction modifier. (around $50.) Depending if you have a dealer discount or not.
Old May 19, 2007 | 04:52 PM
ohnoesaz's Avatar
ohnoesaz
Yes im using mobil 1 75w-140. $15 EACH!!!
It says no modifier needed but I bought a 4oz anyways since i read to add it anyways.
But Im having a problem... I drained it and, although I'm not at that point yet, I CANT FIND THE FILL PLUG ANYWHERE!!! Please help
Old May 19, 2007 | 05:06 PM
daydark's Avatar
daydark
ORIGINAL: ohnoesaz
It's in a really awkward position... it's on the FRONT of the pumpkin (towards the front of the car) on the driver's side. It's above a little flange. You will need to pick up a funnel with a tube running out of it to fill it
Old May 19, 2007 | 05:11 PM
ohnoesaz's Avatar
ohnoesaz
Awe, ok. I have a big powerbuilt pump or a medium syringe, so I'll figure it out. Definately thanks for your help!
ORIGINAL: daydark
ORIGINAL: ohnoesaz
Old May 19, 2007 | 06:01 PM
ohnoesaz's Avatar
ohnoesaz
Any comment on how high to fill it? I've someone say fill hole and someone say there was a 'window' to look inside and fill to that level. Ive seen no window lol.
Thanks
Old May 19, 2007 | 06:20 PM
RodeoFlyer's Avatar
RodeoFlyer
You really can't overfill it. You can, but it will just **** out the vent on the axletube. I would just fill it till it spills out the fill hole and call it a day.
Old May 19, 2007 | 06:21 PM
spuddogg's Avatar
spuddogg
ORIGINAL: RodeoFlyer
...but it will just **** out the vent on the axletube.
There's gotta be a good joke in line somewhere.
