Fog light indicator light
So, this baby has, in the instrument cluster, to the left of the left turn arrow, a fog light indicator. There is no bulb and I have no idea if it is wired by Ford. What I did is ran my own wire and bulb from my switch. You have to remove the instrument cluster and needles to get to it, but it only took me about an hour to do.
[IMG]local://upfiles/28155/C48A3BE8506347A09CFDF10C1309C67E.jpg[/IMG]
Hes right, the brights are blue and in the very center.... Ive never seen that light before, but the outline is there, and it definately doesnt come on when I turn on my fogs. Really, really weird.
The fog lamp indicator on/off in on the headlight switch just above the word 'pull'
the thing your looking at is probably the DLR if equipped (daytime running lights)
whatever light it is ace, i think it's cool.
nicely done
nicely done
ORIGINAL: Ace Guy
You are right Tin Pony. According to the owners manual that came with my car, that is for the DRL. But it is not used, so, on mine, it is now. I think it looks cool, so that's my story and I'm sticking to it. Thought it was odd that there would be a blank there.
Looks really cool, can you give us any more details/tips on how.... what size bulb? do you have IUP? I'd like to use that spot in conjunction with with bluetooth options...
Here’s how I did it.
1 pop off the instrument cluster shroud (no tools just yank)
2 remove gauge cluster (4X 7mm bolts and wire harness)
3 remove front “glass” from cluster (5 snaps) (trip odo button and spring fall out at this time)
4 before you remove the needles, make sure you know exactly what they line up with when the car is off. Then remove needles (if you don’t have the special tool, a small fork would most likely work as the shaft of the needle needs to be gripped when pulling it off)
5 remove the back of cluster (7 snaps)
6 middle piece is what you want. You’ll see the boxes where the indicator lights are.
7 I drilled in from the bottom and stuck in a regular bulb with gel cap (from a aftermarket “mini dash light indicator” was what I used) hit it with some contact cement.
8 routing the wire out the bottom of the cluster, avoiding the odo and if I had a V8, the lower gauges.
9 put everything back in reverse order, not forgetting the trip odo button and spring.
NEEDLE INSTALL
This is the hardest part. Turn the car on for a few seconds then off and the gauges reset their needles. Carefully barely put the needles on the shafts then turn the car on an off to make sure they are correct. Then when you have them correctly done, push the needles all the way down. You can push them down far enough so that that red glow goes away. I do this with the lights on so I can push them down just far enough without being too far.
NEEDLE INSTALL
