3.55 factory gears...do you like them?
Actually they should hook up well. Im sitting at 440hp to the rear wheels and 2 weeks ago cut a 1.744 60' on ET streets. On the stock tires i cut a 1.80. Only suspension mod are Steeda LCA's ...
I HAVE NO CLUE!
But I'm pleased enough that I have no desire to change them. I think the harder work on the engine and less MPG outweigh the small gain you'll get, for daily driving at least.
3.55s are the best compromise imo.
Technically, I don't think the engine works harder with a shorter gear. In fact it's just the opposite. If you do a lot of highway driving then it will work harder because it will rev higher.
ORIGINAL: ohnoesaz
I HAVE NO CLUE!
I HAVE NO CLUE!
With over 415 ft lbs of torque i hook up pretty well while spraying. Anythng bigger would be pointless imho, 3:55's are great when you are putting down big numbers.
breaking
Oct 2, 2015 01:27 PM
Sep 17, 2015 07:57 PM
