Trouble codes P0340 & p0344 HELP PLEASE!!!!!!!!
so far i have a bunch of bolt-ons on my car, including headers, so taking it to ford for warranty work is not very easy, i dont mind buying the part that needs to be replaced, i just need to know what it is... im getting codes p0344 & p0340.. what do i need to do, replace the sensors???? please lmk.. any help is greatly appreciated, and will driving like this hurt anything else in the vehicle??? BTW its a 2006 mustang GT...
thanks, tony
thanks, tony
ORIGINAL: 4.6HighPerformance
thanks, tony
thanks, tony
www.ford-trucks.com/tsb/fulltext/show_article.php?tsb=06-2-9
If you want to try the sensor replacement first, you can order it thru the dealer for about $30. I've read on other forums that after changing the sensor the DTC returned after about an hour. But it may be worth a try if you don't want to use the TSB.
Good luck and hope it all works out for you. -John
